Modifying Kafka Instance Configuration Parameters
Your Kafka instances, topics, and consumers come with default configuration parameter settings. You can modify common parameters on the Kafka console. For details about parameters that are not listed on the console, see the Kafka official website.
Kafka instances have dynamic and static parameters:
- Dynamic parameters: Modifying dynamic parameters will not restart the instance.
 - Static parameters: After static parameters are modified, you must manually restart the instance.
Notes and Constraints
- Configuration parameters of some old instances cannot be modified. Check whether your instance parameters can be modified on the console. If they cannot be modified, contact customer service.
 - This function is not available for single-node instances.
You can modify configuration parameters of a Kafka instance when the instance is in the Running state.
- Log in to the Kafka console.
 - Click
 in the upper left corner to select the region where your instance is located. - Click the desired instance to go to the instance details page.
 - Choose Instance > Parameters.
- To modify a specific parameter, locate the row containing it, and click Edit.
 - To modify parameters in batches, click Modify.
 - To restore parameters to their default values, choose Edit > Restore Default or Modify > Restore Default.
Parameters of v1.1.0 instances are described in Table 1 and Table 2. Parameters of v2.3.0/v2.7/v3.x instances are described in Table 3 and Table 4.
Table 1 Dynamic parameters (v1.1.0 instances) Parameter
Value Range
Default Value
auto.create.groups.enable
Whether to automatically create consumer groups.
You can modify this parameter on the console only for instances created on or after April 25, 2023. For instances created before April 25, 2023, the function of automatically creating consumer groups is enabled by default and cannot be disabled on the console.
true or false
true
offsets.retention.minutes
The longest period a consumption position can be retained starts from the time of submission. Positions retained beyond this duration will be deleted. Each time a consumption position is submitted to a topic partition, its retention period resets to 0.
This is a static parameter for instances created before May 1, 2023.
1,440–30,240
Unit: minute
20,160
Table 2 Static parameters (v1.1.0 instances) Parameter
Value Range
Default Value
min.insync.replicas
If a producer sets the acks parameter to all (or -1), the min.insync.replicas parameter specifies the minimum number of replicas that must acknowledge a write for the write to be considered successful.
1–3
message.max.bytes
Maximum length of a single message.
0–10,485,760
Unit: byte
10,485,760
unclean.leader.election.enable
Indicates whether to allow replicas not in the ISR set to be elected as the leader as a last resort, even though doing so may result in data loss.
true or false
false
connections.max.idle.ms
Idle connection timeout (in ms). Connections that are idle for the duration specified by this parameter will be closed.
5,000–600,000
Unit: millisecond
600,000
log.retention.hours
Message retention duration of an instance, in hours.
This parameter takes effect only for topics that have no aging time configured. If there is aging time configured for topics, it overrides this parameter.
1–168
Unit: hour
72
max.connections.per.ip
The maximum number of connections allowed from each IP address. Request for new connections will be rejected once the limit is reached.
100–20,000
1000
group.max.session.timeout.ms
Maximum session timeout for consumers. A longer timeout gives consumers more time to process messages between heartbeats but results in a longer time to detect failures.
6,000–1,800,000
Unit: millisecond
1,800,000
default.replication.factor
The default number of replicas configured for an automatically created topic.
1–3
3
allow.everyone.if.no.acl.found
- When this parameter is set to true, all users can access resources without ACL rules.
 - When this parameter is set to false, the initial user has all the permissions and other users require authorization.
All the permissions cover modifying a topic, creating and deleting a topic, and changing the number of topic partitions.
This parameter is displayed only when ciphertext access is enabled for the instance.
This parameter cannot be modified for instances created before September 15, 2023.
true or false
true
num.partitions
The default number of partitions configured for each automatically created topic.
1–200
3
group.min.session.timeout.ms
Minimum session timeout for consumers. A shorter timeout enables quicker failure detection but results in more frequent consumer heartbeating, which can overwhelm broker resources.
6,000–300,000
Unit: millisecond
6,000
Table 3 Dynamic parameters (v2.3.0/v2.7/v3.x) Parameter
Value Range
Default Value
min.insync.replicas
1–3
message.max.bytes
0–10,485,760
Unit: byte
10,485,760
true or false
true
100–20,000
1000
true or false
false
1,440–30,240
Unit: minute
20,160
Table 4 Static parameters (v2.3.0/v2.7/v3.x) Parameter
Value Range
Default Value
5,000–600,000
Unit: millisecond
600,000
log.retention.hours
1–168
Unit: hour
72
6,000–1,800,000
Unit: millisecond
1,800,000
1–3
3
true or false
true
num.partitions
1–200
3
6,000–300,000
Unit: millisecond
6,000
 - Click Save.
Modifying dynamic parameters will not restart the instance. Static parameter modification requires manual restart of the instance.
On the Parameters page, view the new parameter values in the Current Value column.
Related Document
To modify parameters of a Kafka instance by calling an API, see Modifying Instance Configurations.
