Applying for Increasing Kafka Quotas
What Is a Quota?
A quota is a limit on the quantity or capacity of a certain type of service resources that you can use, for example, the maximum number of Kafka instances that you can create.
If a quota cannot meet your needs, apply for a higher quota.
How Do I View My Quota?
- Log in to the Kafka console.
- Click
in the upper left corner to select a region and a project. - In the upper right corner of the page, choose Resources > My Quotas.
The Quotas page is displayed.
Figure 1 My Quotas
- On the Quotas page, view the used and total quotas of resources.
If a quota cannot meet your needs, apply for a higher quota by performing the following operations.
How Do I Increase My Quota?
- In the upper right corner of the page, click Increase Quota.
- On the Create Service Ticket page, set the parameters.
In the Problem Description area, enter the required quota and the reason for the quota adjustment.
- Read the agreements and confirm that you agree to them, and then click Submit.
