End Devices
Updated on 2023-11-24 GMT+08:00
These devices can be connected to IEF through edge nodes by using MQTT. After end devices are connected to IEF, you can manage them on IEF in a unified manner.
Registering an End Device
  1. Log in to the IEF console, and click Switch Instance on the Dashboard page to select a platinum service instance.
  2. In the navigation pane, choose Managed Resources > End Devices. Then, click Register End Device in the upper right corner.
  3. Set device parameters.
    • Name: name of an end device.
    • ID: You can customize a device ID or enable IEF to automatically generate an ID. If you want to customize a device ID, select Custom device ID and enter one.
    • Access Protocol: Choose MQTT.
    • Device Configuration: Select an existing device template to add properties for the device automatically. The template defines device properties, twin properties, and device tags. You can also manually add device properties and tags without using a template. The meanings of the properties and tags manually added are the same as those defined in the template. For details, see Device Templates.
      Note: The device template can be selected only when the access protocol of it is the same as that selected during end device registration.
  4. Click Register.
Follow-up Procedure
You can bind end devices to edge nodes. For details, see Binding an End Device to an Edge Node.
