- What's New
- Getting Started
- User Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Instance Management
- Access Control Attribute Management
Permission Set Management
- Adding a System-defined Identity Policy
- Deleting a Permission Set
- Querying Permission Set Details
- Updating a Permission Set
- Deleting a System-defined Identity Policy
- Querying Details About a Custom Identity Policy
- Adding a Custom Identity Policy
- Deleting a Custom Identity Policy
- Listing Accounts Associated with a Permission Set
- Listing System-defined Identity Policies
- Listing Pre-provisioning Statuses of Permission Sets
- Listing Permission Sets
- Creating a Permission Set
- Listing Permission Sets Provisioned to an Account
- Pre-provisioning a Permission Set
- Querying Pre-attachment Status Details of a Permission Set
- Adding a System-defined Policy
- Deleting a System-defined Policy
- Listing System-defined Policies
Account Assignment Management
- Removing Account Assignments
- Querying Details about the Account Assignment Creation Status
- Listing Account Assignment Creation Statuses
- Listing Account Assignment Deletion Statuses
- Listing Users or Groups Associated with an Account and a Permission Set
- Creating Account Assignments
- Querying Details about the Account Assignment Deletion Status
- Tag Management
- User Management
- Group Management
- Group Membership Management
- SCIM User Management
- SCIM Group Management
- Service Provider (SP) Management
- Client Management
- Token Management
- Device Authorization Management
- Authorization Management
- Account Management
- Agency Management
- Credentials Management
- Appendixes
- Change History
Show all
Configuring the Duration of the User Portal Session
By default, the session duration of the user portal is 8 hours, which means the maximum duration for a user to log in to the user portal without re-authentication is 8 hours. After the maximum session duration expires, the user logs out of the user portal and needs to be authenticated again. You can set the duration as follows:
If you use an external identity provider (IdP) as the identity source of IAM Identity Center, the duration of the user portal session is the shorter one that you set in the IdP or IAM Identity Center. For example, if your IdP session duration is 24 hours and you set the session duration to 18 hours in IAM Identity Center, your users must be authenticated again in the user portal after 18 hours.
- Log in to the Huawei Cloud console.
- Click
in the upper left corner of the page and choose Management & Governance > IAM Identity Center.
- Choose Settings in the navigation pane.
- On the Session Settings tab, configure the maximum duration of a session for accessing the user portal.
The maximum session duration is 8 hours by default. You can change the duration from 15 minutes to 90 days.
The drop-down list provides common durations for you to select. You can also select Custom duration and enter a specific duration from 15 minutes to 129,600 minutes.
Figure 1 Session settings - Click Save.
