Updated on 2025-08-07 GMT+08:00
Selecting an MFA Type
You can select a device type for MFA authentication when IAM Identity Center users are prompted for MFA.
  1. Log in to the Huawei Cloud management console.
  2. Click in the upper left corner of the page and choose Management & Governance > IAM Identity Center.
  3. Choose Settings in the navigation pane.
  4. Click the Authentication tab.
  5. In MFA Type, select one of the following MFA types based on service requirements. You can select two MFA types at the same time. For details, see Supported MFA Devices.
    • Authenticator app
    • Security key and built-in authenticator
    Figure 1 Selecting an MFA type
  6. Click Save.
