- What's New
- Getting Started
- User Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Instance Management
- Access Control Attribute Management
Permission Set Management
- Adding a System-defined Identity Policy
- Deleting a Permission Set
- Querying Permission Set Details
- Updating a Permission Set
- Deleting a System-defined Identity Policy
- Querying Details About a Custom Identity Policy
- Adding a Custom Identity Policy
- Deleting a Custom Identity Policy
- Listing Accounts Associated with a Permission Set
- Listing System-defined Identity Policies
- Listing Pre-provisioning Statuses of Permission Sets
- Listing Permission Sets
- Creating a Permission Set
- Listing Permission Sets Provisioned to an Account
- Pre-provisioning a Permission Set
- Querying Pre-attachment Status Details of a Permission Set
- Adding a System-defined Policy
- Deleting a System-defined Policy
- Listing System-defined Policies
Account Assignment Management
- Removing Account Assignments
- Querying Details about the Account Assignment Creation Status
- Listing Account Assignment Creation Statuses
- Listing Account Assignment Deletion Statuses
- Listing Users or Groups Associated with an Account and a Permission Set
- Creating Account Assignments
- Querying Details about the Account Assignment Deletion Status
- Tag Management
- User Management
- Group Management
- Group Membership Management
- SCIM User Management
- SCIM Group Management
- Service Provider (SP) Management
- Client Management
- Token Management
- Device Authorization Management
- Authorization Management
- Account Management
- Agency Management
- Credentials Management
- Appendixes
- Change History
Viewing or Modifying a Permission Set
After a permission set is created, you can view or modify the permission set details and policy settings that the permission set uses, and update the permission set for associated accounts.
Viewing Permission Set Details
- Log in to the Huawei Cloud console.
- Click
in the upper left corner of the page and choose Management & Governance > IAM Identity Center.
- In the navigation pane, choose Multi-Account Permissions > Permission Sets.
- View the created permission sets and their details in the list.
- In the permission set list, click the name of a permission set to view its details, including permissions, accounts, and tags.
Figure 1 Permission set details
Editing a Permission Set
- Click
- In the permission set list, click Edit in the Operation column of the target permission set.
- In the Specify Details step on the displayed page, modify the session duration, initial access page, and description of the permission set, and then click Next.
Figure 2 Specifying details
- In the Set Policy step, modify system-defined policies, custom identity policies, and custom policies and click Next. You can also choose whether to enable Identity Policy.
If policies and custom policies have been configured in the permission set, enabling identity policy will delete them.
Figure 3 Setting policies - In the Confirm step, confirm the modification and click OK.
If a permission set fails to be updated, the permission set status in the account list changes to Outdated. To update the permission set, do as follows:
- Click
- In the permission set list, click the name of a permission set to view its details.
- On the Accounts tab, select the accounts whose permission set status is Outdated and click Update above the list. Alternatively, locate an account whose permission set status is Outdated and click Update in the Operation column.
Figure 4 Updating a permission set
- On the displayed page, confirm the details and click Update in the lower right corner of the page. After the update is complete, the permission set status of the account will be Up to date.
