Help Center/ IAM Identity Center/ User Guide/ Group Management/ Adding Users to or Removing Users from a Group
Updated on 2025-11-27 GMT+08:00
After an IAM Identity Center user is added to or removed from a specific IAM Identity Center group, the user gains or loses the permissions of that group. This way, you can change the user's permissions quickly.
If a user is added to multiple groups, the user inherits the permissions from all these groups.
Adding Users to a Group
  1. Log in to the Huawei Cloud management console.
  2. Click in the upper left corner of the page and choose Management & Governance > IAM Identity Center.
  3. In the navigation pane, choose Groups.
  4. In the group list, click a group name.
    Figure 1 Selecting a group
  5. In the Users in This Group area, click Add User to Group.
  6. In the user list, select the user to be added to the group and click OK.
    Figure 2 Adding users to a group
    Figure 3 Selecting a group
  5. In the user list, locate the user to be removed and click Remove in the Operation column.
  6. Click OK in the displayed dialog box.
    Figure 4 Removing a user from a group
  7. In the user list, select multiple users to be removed and click Remove User from Group.
  8. Click OK in the displayed dialog box.
    Figure 5 Batch removing users
