Updated on 2025-11-07 GMT+08:00
Managing Trust Agency Tags
You can add, modify, or delete tags for created trust agencies and use tags to filter and manage them.
If your organization has configured tag policies for IAM, you can add tags to trust agencies based on the policies. If a tag does not comply with the policies, tag addition may fail. Contact your organization administrator to learn more about tag policies.
  1. Log in to the new IAM console and choose Agencies in the navigation pane.
  2. Click the trust agency name and then the Tags tab.
    • Adding a tag
      1. Click Add Tag in the upper left corner of the tag list.
      2. In the displayed dialog box, enter a tag key and a tag value.
        A tag is a key-value pair that can be used to identify, classify, and search for cloud resources. Here the tags are used to filter and manage trust agencies. A maximum of 20 tags can be added to a trust agency.
        Table 1 describes the key and value of a tag.
        Table 1 Tag parameters
        Example
        Tag key
        A tag key of an IAM user must be unique. You can customize a key or select a key of a tag created in TMS. Tag keys are case insensitive.
        A tag key:
        • Can contain 1 to 64 characters.
        • Can contain only letters, digits, spaces, and special characters (_.:=+-@), but cannot start or end with a space or start with _sys_.
        Key_0001
        Tag value
        A tag value can be repetitive or left blank. The tag values are case-sensitive.
        A tag value:
        • Can contain 0 to 128 characters.
        • Can contain only letters, digits, spaces, and special characters (_.:=+-@).
        Value_0001
      3. Click OK.
    • Editing a tag
      1. Locate the row containing the tag you want to edit and click Edit in the Operation column.
      2. In the displayed dialog box, change the tag value. Table 1 describes the tag parameters.
      3. Click OK.
    • Deleting a tag
      1. Locate the row containing the tag you want to delete and click Delete in the Operation column.
      2. In the displayed dialog box, confirm the tag information.
      3. Click OK.
