Creating a User Group and Assigning Permissions
As an administrator, you can create user groups, and attach identity policies to assign permissions to the user groups. IAM provides system-defined permissions (such as administrator or read-only permissions) for cloud services. You can directly attach these system-defined identity policies to user groups so that the users in the groups can have permissions defined in the identity policies. For details about the system-defined identity policies of all cloud services, see System-defined Permissions.
Before creating a user group, learn about the following:
- Basic concepts about permissions
- For details about the system-defined identity policies of cloud services that use IAM authentication, see System-defined Permissions.
- Log in to the new IAM console as an administrator.
- On the IAM console, choose User Groups from the navigation pane, and click Create User Group in the upper right corner.
Figure 1 Creating a user group
- Enter a user group name.
- Click OK.
You can create a maximum of 20 user groups. To create more user groups, increase the quota by referring to How Do I Increase My Quota?
Assigning Permissions to a User Group
To assign permissions to a user group, do as follows. If you want to revoke permissions from a user group, see Revoking Permissions of a User Group.
- In the user group list, click Authorize in the row that contains the new user group.
Figure 2 Going to the user group authorization page
- On the Authorize User Group page, select the permissions to be assigned to the user group.
Figure 3 Selecting permissions
- Click OK.
Due to system, cache, and other reasons, the identity policies will be applied several minutes after the authorization is complete.
