Help Center/
Host Security Service/
User Guide/
Risk Management/
Container Image Security/
Local Image Security Scan/
Exporting Local Image Scan Results
Updated on 2025-09-08 GMT+08:00
Export image scan results to a local PC.
Exporting Local Image Scan Results from the Risk View
- Log in to the HSS console.
- Click
in the upper left corner and select a region or project.
- In the navigation pane on the left, choose Risk Management > Container Images.
- In Risk View, click System Vulnerabilities, Application Vulnerabilities, or Software Information. Filter Local images, and click Export.
- Wait until an export success message is displayed on the top of the Container Images page. Find the exported file in the default download path on your local PC.
Do not close the browser page during the export, or the export will be interrupted.
Exporting Local Image Scan Results from the Image View
- Click
- On the Image View tab page, select Local Images, click Export, and select a risk type.
Figure 1 Exporting scan results
