Updated on 2025-09-29 GMT+08:00
Installing the Agent in a Cluster
The HSS agent is a piece of software installed on cloud servers to exchange data between the servers and HSS, implementing security check and protection for containers. You can use the HSS only after installing the agent.
HSS can protect Huawei Cloud CCE clusters, third-party cloud clusters, and on-premises clusters. You can select the installation method based on the cluster type.
