Help Center/ Host Security Service/ User Guide/ Proactive Defense/ Dynamic Port Honeypot/ Creating a Protection Policy for a Dynamic Honeypot Port
Updated on 2025-12-12 GMT+08:00
The dynamic port honeypot function uses a real port as a honeypot port to induce attackers to access the port. When enabling the dynamic port honeypot, you need to create a protection policy and add a port as a honeypot port.
This chapter describes how to create a dynamic port honeypot protection policy.
  • A maximum of 50 honeypot ports can be added to a server.
  • A honeypot port can be bound to only one protocol. Both TCP and TCP6 are supported.
  1. Log in to the HSS console.
  2. Click in the upper left corner and select a region or project.
  3. Choose Prevention > Dynamic Port Honeypot.
  4. (Optional) If you have enabled the enterprise project, select the enterprise project where the target server resides from the drop-down list.
  5. On the Servers tab, click Create a Protection Policy. The dialog box is displayed.
  6. Create a protection policy as prompted.
    1. Configure the policy and click Next. For details about related parameters, see Table 1
      Table 1 Parameters for creating a protection policy
      Policy Name
      You can retain the default name or enter a name that is easy to identify.
      OS Type
      Select the OS type of the server where you want to add the port honeypot.
      Protected Port
      Set the honeypot port. HSS provides some common ports by default. For Linux OSs, common Windows ports are provided by default. For Windows OSs, common Linux ports are provided by default. You can modify them as needed.
      Ensure that the port to be added is not occupied by other services. If the port is occupied, the dynamic port honeypot function fails to be enabled.
      (Optional) Source IP address whitelist
      By default, the servers that proactively connect to the dynamic honeypot port are compromised intranet servers. Once a suspicious connection behavior is detected, an alarm is reported.
      Therefore, if a trusted server may connect to the port, you are advised to add the IP address to the source IP address whitelist.
      You can enter IP addresses or CIDR blocks. A maximum of 50 values can be added. Multiple values are separated by commas (,).
    2. Select the target server and click Save and Enable.
      Note that the dynamic port honeypot can be selected only for the servers that meet all the following conditions:
      • The HSS premium edition or higher has been enabled on the server.
      • The server agent is online. The Windows agent version is 4.0.22 or later, and the Linux agent version is 3.2.10 or later.
      • No dynamic port honeypot policies have been bound to the server.
      • The OS type of the server is the same as that specified in 6.a.
      • No EIPs have been bound to the server.
  7. In the Associated Servers column of the created target policy, click the value. The dialog box is displayed.
    Figure 1 Associate servers
  8. In the Port Status column of the associated server, check the port status.
    If a port fails to be enabled, you need to manually enable it. Click Edit Policy, deselect associated servers, and save the policy. Then, click Edit Policy, select servers, and save the policy again. For details about how to edit a policy, see Editing a Policy.
What can I do if the port fails to be enabled?
  • Possible cause 1: The port is occupied by other services.
    Solution: Add other idle ports by editing the policy.
  • Possible cause 2: System resources are insufficient.
    Solution: Free up some system resources. Click Edit Policy, deselect associated servers, and save the policy. Then, click Edit Policy, select servers, and save the policy again. For details about how to edit a policy, see Editing a Policy.
