Help Center/ Host Security Service/ User Guide/ Server Protection/ Virus Scan/ Managing Custom Antivirus Policies
Updated on 2025-01-07 GMT+08:00
A custom antivirus policy is generated for each custom antivirus task that starts periodically or at a specified time point. You can modify or delete such policies as needed.
The policy of a task scheduled to be executed at a specified time point will expire after execution, and will be marked with an expiration tag. You can change the startup time of the policy and enable it again.
Editing a Custom Scan Policy
  2. In the upper left corner of the page, select a region, click , and choose Security & Compliance > HSS.
  3. Choose Server Protection > Virus Scan.
  4. Choose Custom scan policies to view existing user-defined antivirus policies.
  5. In the Operation column of a policy, click Edit. Modify the policy on the edit page.
  6. Click OK.
Delete a Custom Scan Policy
  5. Click Delete in the Operation column of a policy.
    To delete policies in batches, you can also select multiple policies and click Delete in the upper left corner of the list.
  6. Click OK.
