Exporting the Vulnerability List
You can refer to this section to export the vulnerability list.
Prerequisite
The Server Status is Running, Agent Status is Online, and Protection Status is Protected. For details, see Viewing Server Protection Status.
This function is available in HSS professional, enterprise, premium, WTP, and container editions.
Exporting the Vulnerability List (Vulnerability View)
- Log in to the HSS console.
- Click
in the upper left corner and select a region or project. - In the navigation pane, choose Risk Management > Vulnerabilities.
- In the upper left corner of the Vulnerabilities page, click the Vulnerability view tab.
- Click Export above the vulnerability list to export all vulnerability data.
You can select some vulnerability data and click Export to export it. If no data is selected, all data will be exported. A maximum of 200,000 records can be exported.
Figure 1 Exporting the vulnerability list
- View the export status in the upper part of the Vulnerabilities page. After the export is successful, obtain the exported information from the default file download address on the local host.
Do not close the browser page during the export. Otherwise, the export task will be interrupted.
Exporting the Vulnerability List (Server View)
- Click
- In the upper left corner of the Vulnerabilities page, click the Server view tab.
- Export the vulnerability list.
- Export vulnerability details: In the upper part of the vulnerability list, click Export Details to export the vulnerability list.
You can select the risk level, vulnerability handling status, or search criteria to filter the vulnerability information of the target server, and click Export Details to export the vulnerability details.
Figure 2 Exporting vulnerability details
- Export a vulnerability report: In the upper part of the vulnerability list, click Export Report and select a report format.
- When exporting a vulnerability report in HTML format, the vulnerability information about up to 100 servers can be exported. In the exported HTML vulnerability report, you can view vulnerability details.
- When exporting a vulnerability report in PDF format, the vulnerability information about up to 140 servers and vulnerabilities can be exported.
- To export vulnerability reports of some servers, you can select the servers and click Export.
Figure 3 Exporting a vulnerability report
