Updated on 2025-08-26 GMT+08:00
Enabling Application Process Control
HSS can control different types of application processes on servers. Suspicious and trusted processes are allowed to run, and alarms are generated for malicious processes.
You can configure how to enable application process control when creating a whitelist policy. The value of Apply Policy After Learning can be:
  • Automatically: Application process control is automatically enabled after HSS completes learning on the servers associated with the policy.
  • Manually: Manually enable application process control as needed after HSS completes learning. This section describes the detailed procedure.
A whitelist policy has been created and the policy learning outcomes have been confirmed. For details, see Creating a Whitelist Policy and Confirming Learning Outcomes.
  2. In the upper left corner of the page, select a region, click , and choose Security & Compliance > Host Security Service.
  1. In the navigation tree, choose Server Protection > Application Process Control.
  1. Click the Whitelist Policies tab.
  2. In the Operation column of a policy, click Enable Protection.
    You can also select multiple policies and click Enable Protection above the policy list.
  3. In the Enable Protection dialog box, click OK.
  4. Check the policy status. If Policy Status is Learning complete and in effect, application protection has been enabled.
Follow-up Operations
After application process control protection is enabled, alarms will be reported for suspicious and malicious processes running on servers.
