Updated on 2025-08-26 GMT+08:00
Vulnerability Scan
HSS can scan for Linux, Windows, Web-CMS, application, and emergency vulnerabilities. Automatic, scheduled, and manual scans are supported.
  • Automatic scan
    By default, Linux, Windows, and Web-CMS vulnerabilities are automatically scanned every day. Application vulnerabilities are automatically scanned every Monday. The time of an automatic application vulnerability scan changes with the middleware asset scan time. For details about how to view and set the latter, see Asset Discovery.
    If a manual or scheduled vulnerability scan has been performed in a day, HSS will not automatically scan for vulnerabilities on that day.
  • Scheduled scan
    By default, a full server vulnerability scan is performed once a week. To protect workloads, you are advised to set a proper scan period and scan server scope to periodically scan server vulnerabilities.
  • Manual scan
    If you want to view the vulnerability fixing status or real-time vulnerabilities of a server, you are advised to manually scan for vulnerabilities.
This section describes how to manually scan for vulnerabilities and configure a scheduled scan policy.
  • If the agent version of the Windows OS is 4.0.18 or later, application vulnerability scan is supported. If the agent version of the Linux OS is 3.2.9 or later, emergency vulnerability scan is supported. For details about how to upgrade the agent, see Upgrading the Agent.
  • The Server Status is Running, Agent Status is Online, and Protection Status is Protected. Otherwise, vulnerability scan cannot be performed.
  • For details about the types of vulnerabilities that can be scanned by different HSS editions, see Types of Vulnerabilities That Can Be Scanned and Fixed.
  • For details about the OSs supported by Linux and Windows vulnerability scan, see Table 1. Emergency vulnerability scan supports Ubuntu, CentOS, EulerOS, Debian, AlmaLinux, and Windows.
    Table 1 OSs supporting vulnerability scan
    OS Type
    Supported OS
    Windows
    • Windows Server 2019 Datacenter 64-bit English (40 GB)
    • Windows Server 2019 Datacenter 64-bit Chinese (40 GB)
    • Windows Server 2016 Standard 64-bit English (40 GB)
    • Windows Server 2016 Standard 64-bit Chinese (40 GB)
    • Windows Server 2016 Datacenter 64-bit English (40 GB)
    • Windows Server 2016 Datacenter 64-bit Chinese (40 GB)
    • Windows Server 2012 R2 Standard 64-bit English (40 GB)
    • Windows Server 2012 R2 Standard 64-bit Chinese (40 GB)
    • Windows Server 2012 R2 Datacenter 64-bit English (40 GB)
    • Windows Server 2012 R2 Datacenter 64-bit Chinese (40 GB)
    • Windows Server 2022 Datacenter 64-bit English (40 GB)
    • Windows Server 2022 Datacenter 64-bit Chinese (40 GB)
    Linux
    • EulerOS 2.2, 2.3, 2.5, 2.8, 2.9, 2.10, 2.11, 2.12 (64-bit)
    • CentOS 7.4, 7.5, 7.6, 7.7, 7.8 and 7.9 (64-bit)
    • Ubuntu 16.04, 18.04, 20.04, 22.04, 24.04 (64-bit)
    • Debian 9, 10, and 11 (64-bit)
    • Kylin V10, V10 SP1, V10 SP2, and V10 SP3 (64-bit)
    • HCE 1.1 and 2.0 (64-bit)
    • SLES 12 SP5, 15 SP1, and 15 SP2 (64-bit)
    • UnionTech OS V20 server E, V20 server D, 1050u2e, 1050e, 1060e, 1070e (64-bit)
    • Rocky Linux 8.4, 8.5, 8.6, 8.10, 9.0, 9.1, 9.2, 9.4, and 9.5 (64-bit)
    • openEuler 20.03 LTS, 20.03 LTS SP1, 20.03 LTS SP2, 20.03 LTS SP3, 20.03 LTS SP4
    • openEuler 22.03 LTS, 22.03 LTS SP1, 22.03 LTS SP2, 22.03 LTS SP3, 22.03 LTS SP4
    • openEuler 24.03 LTS
    • CTyunOS 3-23.01 (64-bit)
    • AlmaLinux 8.4 (64-bit)
Manual Vulnerability Scan
  2. In the upper left corner of the page, select a region, click , and choose Security & Compliance > Host Security Service.
  3. In the navigation pane, choose Risk Management > Vulnerabilities.
  4. Click Scan in the upper right corner of the Vulnerabilities page.
    To scan for emergency vulnerabilities, locate the row of an emergency vulnerability, and click Scan in the Operation column.
    Figure 1 Manual scan
  5. In the Scan for Vulnerability dialog box displayed, set the vulnerability types and scope to be scanned. For more information, see Table 2.
    Figure 2 Configuring a scan
    Table 2 Parameters for manual scan vulnerabilities
    Example Value
    Type
    Select one or more types of vulnerabilities to be scanned. Possible values are as follows:
    • Linux
    • Windows
    • Web-CMS
    • Application
    • Emergency
    Select all
    Scan
    Select the servers to be scanned. Possible values are as follows:
    • All servers
    • Selected servers
      You can select a server group or search for the target server by server name, ID, EIP, or private IP address. The following servers cannot be selected for vulnerability scan:
      • Servers are protected by basic edition HSS.
      • Servers that are not in the Running state
      • Servers whose agent status is Offline
    All servers
  6. Click OK.
  7. In the upper right corner of the Vulnerabilities page, click Manage Task, and click the Scan Tasks tab. View the scan task execution status.
    In the Operation column of the target scan task, click View Details to view the scan details of a specific server.
    Figure 3 Viewing scan tasks
    You can also choose Asset Management > Servers & Quota and manually scan for vulnerabilities on a single server on the Servers tab page. The procedure is as follows:
    1. Click a server name.
    2. Choose Vulnerabilities.
    3. Click the tab of a vulnerability type to be scanned and click Scan.
Scheduled vulnerability scan
  4. In the upper right corner of the Vulnerabilities page, click Scheduled Scan Policy. The Configure Scheduled Scan Policy dialog box is displayed.
    Figure 4 Scheduled scan policy
  5. In the dialog box, configure parameters such as the period and scope for scheduled vulnerability scanning.
    Figure 5 Configuring a scheduled scan policy
    • Scheduled Vulnerability Scan: Select whether to enable scheduled vulnerability scan. indicates it is enabled.
    • Type: Select the types of vulnerabilities to be scanned.
    • Scan Period: Select Every day, Every three days, or Every week. The default scan duration is 00:00:00 - 07:00:00 and cannot be changed.
    • Servers: Select the server to be scanned. The following servers cannot be selected for vulnerability scan:
      • Servers that use the HSS basic edition
  1. In the upper right corner of the Vulnerabilities page, click Manage Task, and click the Scan Tasks tab. View the scan task execution status.
    Figure 6 Viewing scan tasks
