Updated on 2025-11-07 GMT+08:00
Disabling Application Protection
You can disable application protection if it is no longer needed.
When you disable application protection, the system uninstalls the RASP probes. You can disable application protection in either of the following ways:
  1. Log in to the HSS console.
  2. Click in the upper left corner and select a region or project.
  3. In the navigation pane on the left, choose Server Protection > Application Protection.
  4. In the Operation column of an asset, click Disable Protection.
    If you only need to disable protection for part of the applications on an asset, click View Details in the Operation column of the asset. On the details page, click Disable Protection in the Operation column of specific applications.
  5. On the Disable Protection page, click OK.
    If the RASP status of an asset or application changes to Unprotected, the protection has been disabled.
Deleting Asset Information
  4. In the Operation column of an asset, choose More > Delete.
  5. Check the asset information. If the information is correct, enter DELETE and click OK.
    If the asset is no longer displayed in the asset list, it has been deleted.
