Updated on 2025-12-12 GMT+08:00
Disabling Ransomware Prevention
You can disable ransomware protection as needed. After protection is disabled, your server may be intruded by ransomware. Exercise caution when performing this operation.
  1. Log in to the HSS console.
  2. Click in the upper left corner and select a region or project.
  3. In the navigation pane, choose Prevention > Ransomware Prevention. Click the Protected Servers tab.
  4. Choose More > Disable Protection in the Operation column of the target server.
  5. Confirm the information and click OK.
Follow-up Procedure
After ransomware prevention is disabled, the backup vault continues to back up data. If the server no longer needs backup, you can unbind from the vault in CBR. For details, see Dissociating Resources from a Vault. If you no longer need the vault, you can delete it from CBR. For details, see Deleting a Vault.
