Updated on 2026-09-07 GMT+08:00
Access Process
This section describes how to connect servers and containers to HSS for protection when you use HSS for the first time.
HSS provides asset management, vulnerability detection, baseline check, intrusion detection, ransomware protection, and web tamper protection functions to comprehensively identify security risks in servers and containers, prevent intrusions, and help you build a secure server and container environment.
Access Process
Perform the following operations to connect a server or container to HSS.
Figure 1 Access process
Table 1 Access process description
No.
Step
Purchasing HSS
HSS comes in basic, professional, premium, WTP, and container editions. For details about each edition, see Features. You can purchase an edition based on your protection requirements for servers and containers.
2
The HSS agent is a piece of software installed on cloud servers to exchange data between the servers and HSS, implementing security check and protection for servers and containers. You can use HSS only after installing the agent.
3
Enabling Protection
After you purchase and install the agent, you need to enable HSS to protect servers and containers.
