Managing the Alarm Whitelist
You can configure the alarm whitelist to reduce false alarms. Events can be deleted from the whitelist.
Whitelisted events will not trigger alarms.
On the Alarms page, you can add falsely reported alarms to the alarm whitelist. After an alarm is added to the whitelist, HSS will not generate alarms on it.
Adding Events to the Alarm Whitelist
When handling an alarm event, you can select Add it to alarm whitelist. For details, see Handling Server Alarms.
Checking the Alarm Whitelist
Perform the following steps to check the alarm whitelist:
- Log in to the HSS console.
- Click
in the upper left corner and select a region or project. - In the navigation pane on the left, choose Detection & Response > Whitelists.
- (Optional) If you have enabled the enterprise project function, select an enterprise project from the Enterprise Project drop-down list in the upper part of the page to view its data.
- Click the Alarm Whitelist tab to view the whitelist. For more information, see Alarm whitelist parameters.
Figure 1 Alarm whitelist
Table 1 Alarm whitelist parameters Parameter Name
Alarm Type
Name of the alarm whitelist type.
Whitelist Field
Whitelisted file field
Wildcard
Logic used by a whitelisted rule, which can be equal or include.
Description of the whitelist.
Whitelist Rule
Whitelisted rule ID
Added
Time when an alarm is added to the whitelist.
Enterprise Project
Enterprise project
Occurrences Today
Number of times that alarm events meet the whitelist conditions today.
Total Occurrences
Total number of times that alarm events meet the whitelist conditions. By default, this parameter is not displayed.
Removing an Alarm from the Whitelist
Exercise caution when performing this operation. Whitelisted alarms cannot be restored after removal, and will be reported once triggered. Up to 10,000 alarm whitelist items can be deleted under an account.
- Delete a whitelist item
- In the Operation column of the item, click Delete.
- On the Delete Whitelisted Alarm page, confirm the information to be deleted and determine whether to restore associated alarms.
When adding an alarm to the whitelist, you can whitelist similar alarms. Likewise, when deleting the whitelisted alarm, you can choose whether to restore these similar alarms.
- Enter DELETE in the text box and click OK.
- Return to the alarm whitelist. Verify that the deleted login whitelist item is not displayed.
- Delete multiple alarm whitelist items
- Select whitelist items and click Delete above the list.
When adding an alarm to the whitelist, you can whitelist similar alarms. Likewise, when deleting the whitelisted alarm, you can choose whether to restore the similar alarms.
- Delete all alarm whitelist items
- Click Delete above the alarm whitelist.
- On the Delete All page, confirm the information to be deleted, and choose whether to restore associated alarms.
