Viewing Server Protection Status
Updated on 2025-01-21 GMT+08:00
You are advised to periodically check the server protection status and handle security risks in a timely manner to prevent asset loss.
The server list on the Servers & Quota page displays the protection status of only the following servers:
  • Huawei Cloud servers purchased in the selected region
  • Non-Huawei Cloud servers that have been added to the selected region
  2. In the upper left corner of the page, select a region, click , and choose Security & Compliance > HSS.
  3. In the navigation pane on the left, choose Asset Management > Servers & Quota. On the Servers tab, view the protection status of the server. For details, see Table 1.
    You can also view the server name, ID, IP address, OS, status, and enterprise project on the Servers tab. To select the items to be displayed in the server protection list, click in the upper right corner of the list.
    If your servers are managed by enterprise projects, you can select the target enterprise project to view or operate the asset and detection information.
    Figure 1 Server protection status
    • Searching for a server
      To check the protection status of a server, enter a server name, server ID, or IP address in the search box above the server protection list.
      Figure 2 Searching for a protected server
    • Viewing servers of a certain type
      On the left of the server protection list, select a server protection edition or an asset importance category to view the protection status of each type of servers.
    • Viewing server details
      Hover the cursor on a server name to view the server OS and more details.
    • Viewing server protection information
      The Protection Status column indicates whether a server is protected. The protection status of a server is determined by Agent Status and Server Status. You can view the server risk detection status in the Risk Level column. For details about the preceding parameters, see Table 1.
      Table 1 Protection description
      Server Status
      HSS can only protect running servers. If the server is in the Stopped or other state, you cannot perform security checks or fix risks on the server.
      Agent Status
      • Not installed: The agent has not been installed or successfully started.
        Click Install Agent and install the agent as prompted. For details, see Installing an Agent.
      • Online: The agent is running properly.
      • Offline: The communication between the agent and the HSS server is abnormal, and HSS cannot protect your servers.
        For an IDC server, its information will be automatically deleted from the server management page after its agent goes offline for 30 days.
      Protection Status
      • Enabled: The server is fully protected by HSS.
      • Unprotected: HSS is disabled for the server. After the agent is installed, click Enable in the Operation column to enable protection.
      • Protection interrupted: The server is not protected, because the HSS protection server is interrupted. You can hover the cursor on next to Protection interrupted to view the cause.
      Risk Level
      Risk status of a server. (Data is updated every 24 hours.)
      • Risky: The server has risks. Hover your cursor over a risk icon to view risk distribution details. Click a risk quantity to go to the risk details page.
      • Safe: No risks are found.
      • Pending risk detection: HSS is not enabled for the server.
Viewing the WTP Status
  1. Log in to the management console and go to the HSS page.
  2. Choose Server Protection > Web Tamper Protection and click Servers to view the protection status of the servers.
    To check the protection status of a target server, enter a server name, server ID, or IP address in the search box above the protection list, and click .
    If your servers are managed by enterprise projects, you can select an enterprise project to view or operate the asset and scan information.
    Figure 3 Servers protected by WTP
    Table 2 Statuses
    Protection Status
    Protected: HSS provides static web tamper protection (WTP) for the server.
    Dynamic WTP
    Status of dynamic WTP, which can be:
    • : Dynamic WTP is enabled.
    • : Dynamic WTP is disabled. (After enabling dynamic WTP, restart Tomcat to make this setting take effect.)
    Static Tampering Attacks
    Number of times that static web page files are attacked and tampered with.
    Dynamic Tampering Attacks
    Number of web application vulnerability exploits and injection attacks.
