Help Center/
Distributed Message Service for RocketMQ/
User Guide/
Managing Consumer Groups/
Exporting RocketMQ Consumer Groups
Updated on 2025-07-28 GMT+08:00
A consumer group list can be exported on the RocketMQ console.
- A RocketMQ instance has been purchased.
- A consumer group has been created.
- Log in to the console.
- Click
in the upper left corner to select a region.
DMS for RocketMQ instances in different regions cannot communicate with each other over an intranet. Select a nearest location for low latency and fast access.
- Click
and choose Middleware > Distributed Message Service for RocketMQ to open the console of DMS for RocketMQ.
- Click a RocketMQ instance to go to the instance details page.
- In the navigation pane, choose Instance > Consumer Groups.
- Export a consumer group list in either of the following ways:
- Select the desired consumer groups and choose Export > Export selected data to an XLSX file to export a list of specified consumer groups.
- Choose Export > Export all data to an XLSX file to export all consumer group lists.
