DMS for RocketMQ Metrics
Introduction
This section describes the metrics that DMS for RocketMQ reports to Cloud Eye. You can view metrics and alarms by using the DMS for RocketMQ console.
Namespace
SYS.DMS
Instance Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Conversion Rule |
Monitored Object (Dimension) |
Monitoring Period (Raw Data) |
instance_produce_msg |
Created Messages |
Number of messages received by the instance per minute |
> 0 |
Count |
N/A |
RocketMQ instance |
1 minute |
instance_consume_msg |
Retrieved Messages |
Number of messages retrieved from the instance per minute |
> 0 |
Count |
N/A |
RocketMQ instance |
1 minute |
current_topics |
Topics |
Number of topics in the instance
This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count |
N/A |
RocketMQ instance |
1 minute |
current_queues |
Queues |
Number of queues in the instance
≥ 0 |
Count |
N/A |
RocketMQ instance |
1 minute |
instance_accumulation |
Accumulated Messages |
Total number of messages accumulated in all consumer groups of the instance
≥ 0 |
Count |
N/A |
RocketMQ instance |
1 minute |
instance_produce_scheduled_msg |
Scheduled Messages Created |
Number of scheduled messages received by the instance per minute
This metric is supported for instances purchased on or after July 8 2023. |
≥ 0 |
Count |
N/A |
RocketMQ instance |
1 minute |
instance_retention_period |
Instance Message Retention Period |
Message retention period of the instance
≥ 0 |
ms |
N/A |
RocketMQ instance |
1 minute |
instance_disk_usage |
Instance Disk Usage |
Disk usage of the instance
≥ 0 |
N/A |
RocketMQ instance |
1 minute |
instance_produce_rate |
Instance Creation Rate |
Creation rate of the instance
≥ 0 |
Count/s |
N/A |
RocketMQ instance |
1 minute |
instance_consume_rate |
Instance Retrieval Rate |
Retrieval rate of the instance
≥ 0 |
Count/s |
N/A |
RocketMQ instance |
1 minute |
instance_produce_rate_for_ratelimit |
Converted Production TPS |
Production TPS converted by message size and type, for rate limiting
Available only for RocketMQ 5.x instances. |
≥ 0 |
Count/s |
N/A |
RocketMQ instance |
1 minute |
instance_consume_rate_for_ratelimit |
Converted Consumption TPS |
Consumption TPS converted by message size and type, for rate limiting
≥ 0 |
Count/s |
N/A |
RocketMQ instance |
1 minute |
instance_produce_ratelimit_percentage |
Proportion of Production TPS |
Proportion of production TPS limit that is converted
≥ 0 |
N/A |
RocketMQ instance |
1 minute |
instance_consume_ratelimit_percentage |
Proportion of Consumption TPS |
Proportion of consumption TPS limit that is converted
≥ 0 |
N/A |
RocketMQ instance |
1 minute |
instance_produce_ratelimit_times |
Production Rate Limits |
Number of production rate limit occurrences in one minute
≥ 0 |
Count |
N/A |
RocketMQ instance |
1 minute |
instance_consume_ratelimit_times |
Consumption Rate Limits |
Number of consumption rate limit occurrences in one minute
≥ 0 |
Count |
N/A |
RocketMQ instance |
1 minute |
Broker Metrics
Available for RocketMQ 4.8.0 instances.
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Conversion Rule |
broker_produce_msg |
Created Messages |
Number of messages received by the broker per minute |
> 0 |
Count |
N/A |
RocketMQ instance broker |
1 minute |
broker_consume_msg |
Number of messages retrieved from the broker per minute |
> 0 |
Count |
N/A |
1 minute |
broker_produce_rate |
Message Creation Rate |
Number of messages received by the broker per second |
> 0 |
Count/s |
N/A |
1 minute |
broker_consume_rate |
Message Retrieval Rate |
Number of messages retrieved from the broker per second |
> 0 |
Count/s |
N/A |
1 minute |
broker_total_bytes_in_rate |
Inbound Traffic |
Inbound traffic to the broker per second |
> 0 |
Byte/s |
1024(IEC) |
1 minute |
broker_total_bytes_out_rate |
Outbound Traffic |
Outbound traffic from the broker per second |
> 0 |
Byte/s |
1024(IEC) |
1 minute |
broker_cpu_core_load |
Average Load per CPU Core |
Average load of each CPU core in the broker VM |
> 0 |
N/A |
N/A |
1 minute |
broker_disk_usage |
Disk Capacity Usage |
Disk usage of the broker VM |
0–100 |
N/A |
1 minute |
broker_memory_usage |
Memory Usage |
Memory usage of the broker VM |
0–100 |
N/A |
1 minute |
broker_alive |
Broker Status |
Indicates whether the broker is alive.
1: alive 0: not alive |
N/A |
N/A |
1 minute |
broker_connections |
Connections |
Number of connections used by the VM
≥ 0 |
Count |
N/A |
1 minute |
broker_cpu_usage |
CPU Usage |
CPU usage on the VM
≥ 0 |
N/A |
1 minute |
broker_disk_read_await |
Average Disk Read Time |
Average time for each disk I/O read
≥ 0 |
ms |
N/A |
1 minute |
broker_disk_write_await |
Average Disk Write Time |
Average time for each disk I/O write
≥ 0 |
ms |
N/A |
1 minute |
broker_produce_p99 |
Message Creation Processing (99th Percentile) |
The 99th percentile of time taken to process all creation requests, in ascending order
≥ 0 |
ms |
N/A |
1 minute |
broker_produce_p999 |
Message Creation Processing (99.9th Percentile) |
The 99.9th percentile of time taken to process all creation requests, in ascending order
≥ 0 |
ms |
N/A |
1 minute |
broker_retention_period |
How long ago the earliest message was saved on the broker
≥ 0 |
Hours |
N/A |
1 minute |
broker_produce_success_rate |
Creation Success Rate |
Percentage of creations that were successfully requested on the broker
≥ 0 |
N/A |
1 minute |
broker_produce_scheduled_msg |
Scheduled Messages Created per Minute |
Number of scheduled messages created on the broker per minute
≥ 0 |
Count |
N/A |
1 minute |
broker_disk_read_rate |
Disk Read Speed |
Read traffic on the disk
≥ 0 |
Byte/s |
1024(IEC) |
1 minute |
broker_disk_write_rate |
Disk Write Speed |
Write traffic on the disk
≥ 0 |
Byte/s |
1024(IEC) |
1 minute |
Topic Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Conversion Rule |
topic_produce_msg |
Created Messages |
Number of messages received by the topic per minute |
> 0 |
Count |
N/A |
RocketMQ instance queue |
1 minute |
topic_consume_msg |
Number of messages retrieved from the topic per minute |
> 0 |
Count |
N/A |
1 minute |
topic_produce_rate |
Number of messages received by the topic per second |
> 0 |
Count/s |
N/A |
1 minute |
topic_consume_rate |
Number of messages retrieved from the topic per second |
> 0 |
Count/s |
N/A |
1 minute |
topic_bytes_in_rate |
Message Creation |
Message creation traffic of the topic
≥ 0 |
Byte/s |
1024(IEC) |
1 minute |
topic_bytes_out_rate |
Message Retrieval |
Message retrieval traffic of the topic
≥ 0 |
Byte/s |
1024(IEC) |
1 minute |
Consumer Group Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Conversion Rule |
group_consume_msg |
Number of messages retrieved by the consumer group per minute
This metric is available only when Topic is set to All topics on the By Consumer Group tab page. |
> 0 |
Count |
N/A |
Consumer group of a RocketMQ instance |
1 minute |
group_accumulation |
Available Messages |
Number of messages accumulated in the consumer group Unit: count
> 0 |
Count |
N/A |
1 minute |
group_topic_consume_msg |
Number of messages in the specified topic that are retrieved by the consumer group per minute
This metric is available only when Topic is set to a specified topic on the By Consumer Group tab page. |
> 0 |
Count |
N/A |
1 minute |
group_topic_consume_rate |
Number of messages in the specified topic that are retrieved by the consumer group per second
> 0 |
Count/s |
N/A |
1 minute |
group_topic_accumulation |
Number of messages in a specific topic
> 0 |
Count |
N/A |
1 minute |
consumer_subscription_consistency |
Subscription Consistency |
Indicates whether the subscription relationships of consumers in the group were consistent in the past minute.
N/A |
N/A |
1 minute |
Dead Letter Queue Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Conversion Rule |
dlq_accumulation |
Messages in the Dead Letter Queue |
Number of messages in the dead letter queue |
≥ 0 |
Count |
N/A |
Dead letter queue of a RocketMQ instance |
1 minute |
dlq_increase |
Dead Letter Message Increase |
Number of messages increased within one minute in the dead letter topic |
≥ 0 |
Count |
N/A |
1 minute |
Dimensions
Key |
Value |
reliablemq_instance_id |
RocketMQ instance |
reliablemq_broker |
reliablemq_topics |
reliablemq_groups |
reliablemq_groups_topics |
Consumer group of a RocketMQ instance queue |
reliablemq_dlq_topics |
