Resource Topology
In Slurm, the topology.conf file defines the physical topology of a cluster (such as the rack or switch layer) to optimize job scheduling policies (such as by preferentially allocating adjacent nodes).
The following is a detailed description and example of the configuration file.
Basic Syntax
SwitchName=<layer-name>[Nodes=<node-list>][Switches=<sub-layer-list>][Children=<number-of-child-nodes>]
- SwitchName: defines the name of a topology layer (for example, rack or switch).
- Nodes: lists the nodes (for example, node[1-10]) at the topology layer.
- Switches: indicates the sub-layers (used for the nested structure) contained in the topology layer.
- Children: indicates the number of sub-layers. This field is optional.
Configuration Examples
- Single-layer topology (racks and nodes)
# Define two racks (rack1 and rack2). Each rack contains 10 nodes. SwitchName=rack1 Nodes=node[1-10] SwitchName=rack2 Nodes=node[11-20]
- Multi-layer topology (cluster, racks, switches, and nodes)
# Cluster (cluster1 is deployed across two equipment rooms.) SwitchName=cluster1 Switches=room1,room2 # Equipment room (There are two racks in room1.) SwitchName=room1 Switches=rack1,rack2 # Rack (There are two switches on rack1.) SwitchName=rack1 Switches=switch1,switch2 # Switch (switch1 connects to 10 nodes.) SwitchName=switch1 Nodes=node[1-10] SwitchName=switch2 Nodes=node[11-20]
- Hybrid layer (switches and nodes)
# The rack houses switches and nodes. SwitchName=rack1 Nodes=node1,node2 Switches=switch1 SwitchName=switch1 Nodes=node3,node4
Key Parameters
Parameter |
Description |
Nodes |
List of continuous or discrete nodes in the format of node[1-5,10]. |
Switches |
List of sub-layer names (used to define the nested structure, such as a rack containing switches). |
Children |
Number of sub-layers. For example, Children=2 indicates two sub-layers. This parameter is usually used together with Switches. |
Verification
- Check the topology structure.
scontrol show topology
Example output:
- View the topology associated with a node.
scontrol show node node01
The SwitchName field in the output indicates the topology layer.
NodeName=node01 ... SwitchName=rack1
- Submit a test job.
# Allocate two nodes on the same rack. sbatch --nodes=2 --switches=1@rack1 --wrap="hostname" squeue -o "%N" # Check whether the allocated nodes are on rack1.
FAQ
- A node is not associated with any layer.
- Symptom: SwitchName in the scontrol show node command output is empty.
- Solution: Check whether the Nodes parameter contains the node.
- There are syntax errors.
- Symptom: slurmctld fails with an error message "invalid topology.conf" displayed in the log.
- Solution: Run the scontrol reconfigure command to reload the configuration and then view the log.
tail -f /var/log/slurm/slurmctld.log
- Failed to allocate nodes for a job.
- Reason: The value of the --switches parameter exceeds the capacity of the actual layer.
- Example: If rack1 has only 10 nodes, submitting --nodes=12 --switches=1@rack1 will fail.
Best Practices
- Align with the actual hardware.
Ensure that the hierarchy (such as racks and switches) in topology.conf is consistent with the physical environment configuration.
- Reduce the number of layers.
Do not nest too many layers (for example, clusters, equipment rooms, racks, switches, and nodes). Generally, two or three layers are enough.
- Limit the use of topology resources based on QoS.
Configuration Example (Dynamic Resource Partitioning)
# Define the independent topology of GPU nodes. SwitchName=gpu_rack Nodes=gpu[1-4] # A dedicated rack for GPU nodes # Specify the GPU topology when submitting a job. sbatch --gres=gpu:2 --switches=1@gpu_rack job.sh
