Interaction Between HPC-S² and Other Services
| Service | Interaction with HPC-S² | Reference |
| Elastic Cloud Server (ECS) | You can purchase ECSs to create HPC clusters or use existing ECSs to deploy HPC clusters. | |
| Virtual Private Cloud (VPC) | The cloud servers required for the same high-performance computing task are located in a single VPC, where subnets and security groups are configured for access control. | |
| Image Management Service (IMS) | You can use public, private, or shared images to create cloud servers required for high-performance computing. You can also create private images from the cloud servers fulfilling high-performance computing. | |
| Elastic Volume Service (EVS) | EVS disks can be attached to cloud servers to provide additional storage. | |
| Scalable File Service (SFS) | SFS provides hosted shared file storage for cloud servers. |
