User Guide
- Overview
- Typical Applications in the ECS Scenario
- Best Practices in the ECS Scenario
- Typical Applications in the BMS Scenario
- Change History
HPC-S² User Guide
- Overview
- Getting Started
- User Guide
- Why Am I Still Charged After I Deleted My Cluster?
- What Can I Do If a Compute Node Cannot Be Found or Fails to Be Added to a Cluster?
- If I Fail to Deploy a Cloud Server in a Cluster, Can I Deploy It in Another Cluster?
- What Can I Do If I Receive Error Message "Insufficient EIP quota"?
- What Can I Do If the Maximum Number of Clusters Has Been Reached?
- What Can I Do If I Receive Error Message "master node cannot reached" But the Master Node is Running?
On this page
Help Center/
High Performance Computing/
HPC-S² User Guide/
Overview/
HPC-S² Application and Usage Restrictions
HPC-S² Application Scenarios
- HPC-S² allows you to create HPC clusters with a few clicks. During the cluster creation, the schedulers, domain controllers, and runtime dependency are automatically deployed.
- You can manage clusters and nodes and view their status on the HPC-S² console.
HPC-S² Usage Restrictions
- The HPC-S² solution is available only in the AP-Singapore region.
- Only Slurm and SGE schedulers can be used for scheduling.
- The SGE scheduler can be in the Kunpeng or x86 architecture, but the Slurm scheduler can only be in the x86 architecture.
- A single user can create a maximum of three clusters.
- A cluster can contain a maximum of 2,000 compute nodes.
- Data disks cannot be automatically attached to compute nodes. If needed, you can manually attach them for use.
- If nodes fail to be created or added, the cluster cannot be automatically restored.
- Only CentOS 7 series public images can be used during cluster creation or capacity expansion.
- If the EIPs or data disks of the nodes are not deleted when the nodes are deleted, they will still incur fees.
- Do not perform operations on the nodes in the HPC cluster on the ECS console. Otherwise, the cluster may encounter with errors.
- Do not modify or delete files in the /usr/local/.hpccluster directory. Otherwise, the cluster may encounter errors.
The authorized_keys file in the /usr/local/.hpccluster/role/.ssh/ directory is used only for system maintenance.
- The clusters created by users with different member accounts cannot have duplicated names if such users belong to the same master account.
Parent topic: Overview
