User Guide
- Overview
- Typical Applications in the ECS Scenario
- Best Practices in the ECS Scenario
- Typical Applications in the BMS Scenario
- Change History
HPC-S² User Guide
- Overview
- Getting Started
- User Guide
- Why Am I Still Charged After I Deleted My Cluster?
- What Can I Do If a Compute Node Cannot Be Found or Fails to Be Added to a Cluster?
- If I Fail to Deploy a Cloud Server in a Cluster, Can I Deploy It in Another Cluster?
- What Can I Do If I Receive Error Message "Insufficient EIP quota"?
- What Can I Do If the Maximum Number of Clusters Has Been Reached?
- What Can I Do If I Receive Error Message "master node cannot reached" But the Master Node is Running?
Show all
Open MPI Delivered with the IB Driver
This section describes how to install and use Open MPI (version 4.0.2a1 is used as an example) delivered with the IB driver on a BMS.
Perform the operations on each BMS in a cluster.
Password-free login has been configured between BMSs in the cluster.
- Check whether the IB driver has been installed.
- Install the IB driver.
- Download the installation package MLNX_OFED_LINUX-4.6-1.0.1.1-rhel7.6alternate-aarch64.tgz.
Download path: https://network.nvidia.com/products/infiniband-drivers/linux/mlnx_ofed/
Figure 2 IB driver download center - Run the following commands to install the software package:
# tar -xvf MLNX_OFED_LINUX-4.6-1.0.1.1-rhel7.6alternate-aarch64.tgz
# cd MLNX_OFED_LINUX-4.6-1.0.1.1-rhel7.6-x86_64/
# ./mlnxofedinstall
- Install and configure UCX.
- Download the UCX installation package.
# cd /opt && wget https://github.com/openucx/ucx/releases/download/v1.6.0/ucx-1.6.0.tar.gz
# cd /opt/ucx-1.6.0
# yum install autoconf automake libtool numactl-devel -y
# ./contrib/configure-release --prefix=/opt/ucx160 --enable-optimizations
# make && make install
- Configure UCX.
- Create non-root user rhel.
# useradd rhel; su - rhel
- Obtain PKEY, delete the third digit of PKEY, and use this value to replace {pkey} in 4.d.
# cat /sys/class/infiniband/mlx5_0/ports/1/pkeys/* | grep -v 0000 | head -n1
For example, if the obtained PKEY is 0x8f05, delete the third digit to obtain 0xf05.
Figure 3 Obtaining PKEY - Obtain UCX PKEY.
- Replace PKEY in UCX.
# sed -i 's/0x[a-f0-9]*/{pkey}/g' ucx.env
In this example, run sed -i 's/0x[a-f0-9]*/0xf05/g' ucx.env.
Figure 4 Replacing PKEY in UCX - Set UCX PKEY as an environment variable.
# sed -i 's/^UCX/export UCX/g' ucx.env
# cat ucx.env >> ~/.bashrc
- Configure MPI environment variables.
- Use VIM to open the ~/.bashrc file and add the following data to the file:
export PATH=$PATH:/usr/mpi/gcc/openmpi-4.0.2a1/bin
export LD_LIBRARY_PATH=/usr/mpi/gcc/openmpi-4.0.2a1/lib64
- Run the following command to check whether the MPI environment variables are correct:
If information shown in Figure 5 is displayed, environment variables have been configured.
- Run the following command to run Open MPI delivered with the IB driver on a BMS:
#mpirun -np 2 -mca btl_openib_if_include "mlx5_0:1" -x MXM_IB_USE_GRH=y /usr/mpi/gcc/openmpi-3.1.0rc2/tests/imb/IMB-MPI1 PingPong
Figure 6 Running Open MPI delivered with the IB driver
