Skill Overview
A skill can be abstractly understood as "algorithm model + logic code". The algorithm model handles AI inference, and the logic code handles inference result processing.
This section describes how to use empty templates and basic skill templates to develop skills on the Huawei HiLens console.
Skill
A skill is an AI application ready to run on a camera or another computing device. It consists of a model and logic code. The logic code is the skill's framework that governs how the skill behaves, including data reading, model import, model inference, and result output. The model is an AI algorithm trained using big data and handles inference while the skill is running.
The Skill Market of Huawei HiLens provides extensive skills for users.
- The application scenarios for HiLens skills include smart campus, smart home, smart vehicle-mounted terminals, smart shopping mall, and more.
 - Skills are classified into two types by device: skills for Ascend chips and skills for HiSilicon Hi35xx series chips.
    Figure 1 Skill card
Skill Development Overview
Skills are classified into two types based on the chip types: skills used on HiLens Kit devices and skills used on devices that run HiSilicon Hi35xx series chips. The HiLens platform supports quick, convenient, and efficient skill development using skill templates. It also allows you to develop models and logic code without using templates, meeting your personalized requirements in more scenarios.
Skills that run on HiSilicon Hi35xx series chips require a large chip memory and high performance. You need to optimize the skill models. If you want to develop skills of this type, contact the support team of the Huawei HiLens platform.
Developing New Skills on the Console
Before creating a skill, determine its type. Different skills have different models and logic code, but their creation process is the same.
   Developing skills on the Huawei HiLens console may occupy OBS resources and incur fees. For details about OBS pricing, see Product Pricing Details.
For details about the skill creation process, see Figure 2.
- Using basic skill templates: Ensure that there are available basic skill templates on the platform.
 - Using empty templates: To develop a skill using an empty template, you need to develop its model and logic code. If your model format does not meet our requirements, the Huawei HiLens platform will convert the model format during model import.
        Category  |
        Common Operation  |
        Quick Link  |
        Using a skill template  |
        Obtain a skill template.  |
        Create a skill using the basic skill template.  |
        Using an empty template  |
        Develop a model.  |
        Import (convert) the model.  |
        Compile the logic code.  |
        Create a skill using the empty template.  |
Related Operations
On the Huawei HiLens platform, you cannot only develop skills, but also manage your developed skills. The detailed operations are as follows.
        Operation  |
        Description  |
        After determining the type of the skill to be developed, create the skill according to Developing New Skills on the Console.  |
        After a skill is created, you can edit and modify the skill, including its basic information, content, and runtime configurations.  |
        After a skill is created, you can deploy it to devices, view the skill videos to check its effects, and debug it repeatedly.  |
        You can delete skills that are no longer used to release resources.  |
