Configuring an Alarm Rule
Configuring alarm rules for FlexusX instances allows you to customize the monitored objects and notification policies. They let you can monitor your FlexusX instances more carefully.
This section describes how to configure an alarm rule for a FlexusX instance.
Configuring an Alarm Rule on the Cloud Eye Console
- Log in to the Cloud Eye console.
- Click in the upper left corner and select the desired region and project.
- In the navigation pane, choose Alarm Management > Alarm Rules.
- On the Alarm Rules page, click Create Alarm Rule to create one, or modify an existing alarm rule.
For more information about alarm rules, see Introduction to Alarm Rules.
