Configuring the HTTP Proxy
When you use KooCLI to manage and access cloud resources, cloud service APIs may fail to be called due to the intranet access restriction of your company. In this case, you can use the HTTP proxy by configuring the environment variables http_proxy and https_proxy.
Configuring the Environment Variable http_proxy
Run the command that matches your OS, to configure the environment variable http_proxy.
- Linux or macOS
- Temporary environment variable
Run the following command to configure http_proxy:
export http_proxy="http://username:password@proxyServer:port"
In the preceding command, proxyServer indicates the domain name (if resolvable) or IP address of the proxy server, and port indicates the port number. Enter a username and password if required, or run the following command:
export http_proxy="http://proxyServer:port"
- Permanent environment variable
To permanently configure http_proxy in an environment variable that takes effect only for the current user, add the following content to the ~/.bashrc file:
After configuring the permanent environment variable, log out and log in again for the variable to take effect.
- Windows
- Using Command Prompt
set http_proxy=http://username:password@proxyServer:port
In the preceding command, proxyServer indicates the domain name (if resolvable) or IP address of the proxy server, and port indicates the port number. Enter a username and password if required, or run the following command:set http_proxy=http://proxyServer:port
Run the following command to permanently configure http_proxy in an environment variable that takes effect only for the current user:
setx "http_proxy" "http://username:password@proxyServer:port"
setx "http_proxy" "http://proxyServer:port"
The permanent environment variable will take effect on the clients opened later.
- Using PowerShell
$env:http_proxy="http://username:password@proxyServer:port"
In the preceding command, proxyServer indicates the domain name (if resolvable) or IP address of the proxy server, and port indicates the port number. Enter a username and password if required, or run the following command:$env:http_proxy="http://proxyServer:port"
[environment]::SetEnvironmentvariable("http_proxy", "http://username:password@proxyServer:port", "User")In the preceding command, proxyServer indicates the domain name (if resolvable) or IP address of the proxy server, and port indicates the port number. Enter a username and password if required, or run the following command:
[environment]::SetEnvironmentvariable("http_proxy", "http://proxyServer:port", "User")The permanent environment variable will take effect on the clients opened later.
Configuring the Environment Variable https_proxy
Run the command that matches your OS, to configure the environment variable https_proxy.
- Linux or macOS
Run the following command to configure https_proxy:
export https_proxy="https://username:password@proxyServer:port"
export https_proxy="https://proxyServer:port"
To permanently configure https_proxy in an environment variable that takes effect only for the current user, add the following content to the ~/.bashrc file:
- Windows
set https_proxy=https://username:password@proxyServer:port
set https_proxy=https://proxyServer:port
Run the following command to permanently configure https_proxy in an environment variable that takes effect only for the current user:
setx "https_proxy" "https://username:password@proxyServer:port"
setx "https_proxy" "https://proxyServer:port"
- Using PowerShell
$env:https_proxy="https://username:password@proxyServer:port"
$env:https_proxy="https://proxyServer:port"
[environment]::SetEnvironmentvariable("https_proxy", "https://username:password@proxyServer:port", "User")In the preceding command, proxyServer indicates the domain name (if resolvable) or IP address of the proxy server, and port indicates the port number. Enter a username and password if required, or run the following command:
[environment]::SetEnvironmentvariable("https_proxy", "https://proxyServer:port", "User")The permanent environment variable will take effect on the clients opened later.
