- Function Overview
- What's New
- Getting Started
User Guide
- Configuration Management
- HTTP Proxy
- Commonly Used Commands
Options
- Option Overview
- Printing Help Information
- Printing Debugging Information
- Generating API Input Parameter Skeleton in JSON Format
- Checking Command
- Specifying Region
- Calling APIs with AK/SK in Non-configuration Mode
- Specifying Account ID
- Specifying Profile
- Specifying Authentication Mode
- Specifying Output Format
- Passing API Parameters with JSON File
- Specifying Request Timeouts
- Specifying Retry Count
- Skipping HTTPS Request Certificate Verification
- Specifying a Domain Name
- Polling Results
- Obtaining CLI Examples on API Explorer
- Using KooCLI in Non-configuration Mode
- Online Experience
- Obtaining Authentication Information
- Overview
- Authentication
- Profiles
- Metadata Cache
- Logs
- Network Connections
- Cloud Services
- Cloud Service APIs
- Regions
Parameters
- What Are KooCLI System Parameters?
- Why Am I Seeing a Message Indicating an Invalid Parameter?
- Why Are Old and New KooCLI System Parameters (Such as region and cli-region) Available? Which Parameters Are Recommended?
- Why Am I Seeing a Message Indicating a Duplicate Parameter?
- How Do I Use cli-jsonInput?
- When Can I Use cli-jsonInput?
- Why Am I Seeing a Message Indicating an Unsupported Parameter Position or Type?
- How Do I Leave a Body Parameter Empty for Cloud Service APIs?
- Interactive Mode and Autocomplete
Output Formats
- What Output Formats Are Supported by KooCLI?
- How Do I Define a JMESPath Expression?
- Which KooCLI System Parameters Are Related to Data Output? Which Ones Are Recommended?
- How Do I Use cli-output, cli-query, and cli-output-num?
- How Do I Use cli-output-rows, cli-output-cols, and cli-output-num? What Are the Precautions?
- How Do I Use cli-json-filter? What Are the Precautions?
- Other
- Videos
Show all
Features
- Restart
Click Reload to restart the current instance. Restarting an instance will terminate all on-going sessions and create a session. Any ongoing process will be terminated, and data that is not persistently stored will be cleared.
- Settings
Click Settings to set the font size and style of the current instance.
- Upload/Download
You can upload files to the user directory in the workspace. You can also download a file in the workspace to a local directory.
Click Upload or Download to upload or download a file.
- Resource manager
Manage files in the user directory of the current instance.
Click Explorer to open the file manager.
The file manager is displayed, as shown in the following figure. Right-click the icon in the red box and close or collapse the file view.
- Terminal
The CLI integrates the functions of online terminals. You can create multiple terminals on it. When multiple terminals are opened, all of them are connected to the same instance. The number of instances does not increase as you open a new terminal.
Click New Terminal to create a terminal.
- Help
Click Help to obtain more support information or view the privacy statement.
