- Function Overview
- What's New
- Getting Started
User Guide
- Configuration Management
- HTTP Proxy
- Commonly Used Commands
Options
- Option Overview
- Printing Help Information
- Printing Debugging Information
- Generating API Input Parameter Skeleton in JSON Format
- Checking Command
- Specifying Region
- Calling APIs with AK/SK in Non-configuration Mode
- Specifying Account ID
- Specifying Profile
- Specifying Authentication Mode
- Specifying Output Format
- Passing API Parameters with JSON File
- Specifying Request Timeouts
- Specifying Retry Count
- Skipping HTTPS Request Certificate Verification
- Specifying a Domain Name
- Polling Results
- Obtaining CLI Examples on API Explorer
- Using KooCLI in Non-configuration Mode
- Online Experience
- Obtaining Authentication Information
- Overview
- Authentication
- Profiles
- Metadata Cache
- Logs
- Network Connections
- Cloud Services
- Cloud Service APIs
- Regions
Parameters
- What Are KooCLI System Parameters?
- Why Am I Seeing a Message Indicating an Invalid Parameter?
- Why Are Old and New KooCLI System Parameters (Such as region and cli-region) Available? Which Parameters Are Recommended?
- Why Am I Seeing a Message Indicating a Duplicate Parameter?
- How Do I Use cli-jsonInput?
- When Can I Use cli-jsonInput?
- Why Am I Seeing a Message Indicating an Unsupported Parameter Position or Type?
- How Do I Leave a Body Parameter Empty for Cloud Service APIs?
- Interactive Mode and Autocomplete
Output Formats
- What Output Formats Are Supported by KooCLI?
- How Do I Define a JMESPath Expression?
- Which KooCLI System Parameters Are Related to Data Output? Which Ones Are Recommended?
- How Do I Use cli-output, cli-query, and cli-output-num?
- How Do I Use cli-output-rows, cli-output-cols, and cli-output-num? What Are the Precautions?
- How Do I Use cli-json-filter? What Are the Precautions?
- Other
- Videos
On this page
Show all
Use cli-endpoint to specify a domain name of the target cloud service. By default, KooCLI sends requests to the target cloud service in the relevant region. You can also specify an endpoint of this cloud service.
hcloud IoTDA UpdateDevice --cli-region="ap-southeast-1" --description="test update device" --device_id="testz*********************0802" --cli-endpoint="iot-mqtts.ap-southeast-1.myhuaweicloud.com" { "app_id" : "103b************************6202", "app_name" : "DefaultApp_********", "device_id" : "testz*********************0802", "node_id" : "testz*********************0802", "gateway_id" : "testz*********************0802", "device_name" : "test********************************************0802", "node_type" : "CATEWAY", "description" : "test update device", "fw_version" : null, "sw_version" : null, "device_sdk_version" : null, "auth_info" : { "auth_type" : "CERTIFICATES" "secret" : null, "fingerprint" : "e30db21************************b1772929c", "secure_access" : true, "timeout" : 0 } "product_id" : "50c1************************588e", "product_name" : "50c1************************588e", "status" : "INACTIVE", "create time" : "20220801T085024z", "tags" : [], "extension_info" : { "shal_fingerprint" : "82cd23e2************************e089d59d", "sha256_fingerprint" : "396ldb************************************************4a5f88ccb7" } }
Parent topic: Options
