- Function Overview
- What's New
- Getting Started
User Guide
- Configuration Management
- HTTP Proxy
- Commonly Used Commands
Options
- Option Overview
- Printing Help Information
- Printing Debugging Information
- Generating API Input Parameter Skeleton in JSON Format
- Checking Command
- Specifying Region
- Calling APIs with AK/SK in Non-configuration Mode
- Specifying Account ID
- Specifying Profile
- Specifying Authentication Mode
- Specifying Output Format
- Passing API Parameters with JSON File
- Specifying Request Timeouts
- Specifying Retry Count
- Skipping HTTPS Request Certificate Verification
- Specifying a Domain Name
- Polling Results
- Obtaining CLI Examples on API Explorer
- Using KooCLI in Non-configuration Mode
- Online Experience
- Obtaining Authentication Information
- Overview
- Authentication
- Profiles
- Metadata Cache
- Logs
- Network Connections
- Cloud Services
- Cloud Service APIs
- Regions
Parameters
- What Are KooCLI System Parameters?
- Why Am I Seeing a Message Indicating an Invalid Parameter?
- Why Are Old and New KooCLI System Parameters (Such as region and cli-region) Available? Which Parameters Are Recommended?
- Why Am I Seeing a Message Indicating a Duplicate Parameter?
- How Do I Use cli-jsonInput?
- When Can I Use cli-jsonInput?
- Why Am I Seeing a Message Indicating an Unsupported Parameter Position or Type?
- How Do I Leave a Body Parameter Empty for Cloud Service APIs?
- Interactive Mode and Autocomplete
Output Formats
- What Output Formats Are Supported by KooCLI?
- How Do I Define a JMESPath Expression?
- Which KooCLI System Parameters Are Related to Data Output? Which Ones Are Recommended?
- How Do I Use cli-output, cli-query, and cli-output-num?
- How Do I Use cli-output-rows, cli-output-cols, and cli-output-num? What Are the Precautions?
- How Do I Use cli-json-filter? What Are the Precautions?
- Other
- Videos
On this page
Show all
Checking Command
The dryrun option is used to check the correctness of a command. Add --dryrun in a command. The system prints the request message after verification. It does not call the target API.
hcloud RDS CreateConfiguration --cli-region="ap-southeast-1" --project_id="0dd8cb****************19b5a84546" --datastore.type="MySQL" --datastore.version="5.7" --values.max_connections="10" --name="test-001" --description="test create configuration" --dryrun -------- The execution is eliminated in dry-run mode. Current request: -------- POST https://rds.ap-southeast-1.myhuaweicloud.com/v3/0dd8cb****************19b5a84546/configurations Content-Type: application/json X-Project-Id: 0dd8cb****************19b5a84546 X-Sdk-Date: 20220621T103331Z Authorization: **** { "datastore": { "type": "MySQL", "version": "5.7" }, "description": "test create configuration", "name": "test-001", "values": { "max_connections": "10" } }
Parent topic: Options
