- Function Overview
- What's New
- Getting Started
User Guide
- Configuration Management
- HTTP Proxy
- Commonly Used Commands
Options
- Option Overview
- Printing Help Information
- Printing Debugging Information
- Generating API Input Parameter Skeleton in JSON Format
- Checking Command
- Specifying Region
- Calling APIs with AK/SK in Non-configuration Mode
- Specifying Account ID
- Specifying Profile
- Specifying Authentication Mode
- Specifying Output Format
- Passing API Parameters with JSON File
- Specifying Request Timeouts
- Specifying Retry Count
- Skipping HTTPS Request Certificate Verification
- Specifying a Domain Name
- Polling Results
- Obtaining CLI Examples on API Explorer
- Using KooCLI in Non-configuration Mode
- Online Experience
- Obtaining Authentication Information
- Overview
- Authentication
- Profiles
- Metadata Cache
- Logs
- Network Connections
- Cloud Services
- Cloud Service APIs
- Regions
Parameters
- What Are KooCLI System Parameters?
- Why Am I Seeing a Message Indicating an Invalid Parameter?
- Why Are Old and New KooCLI System Parameters (Such as region and cli-region) Available? Which Parameters Are Recommended?
- Why Am I Seeing a Message Indicating a Duplicate Parameter?
- How Do I Use cli-jsonInput?
- When Can I Use cli-jsonInput?
- Why Am I Seeing a Message Indicating an Unsupported Parameter Position or Type?
- How Do I Leave a Body Parameter Empty for Cloud Service APIs?
- Interactive Mode and Autocomplete
Output Formats
- What Output Formats Are Supported by KooCLI?
- How Do I Define a JMESPath Expression?
- Which KooCLI System Parameters Are Related to Data Output? Which Ones Are Recommended?
- How Do I Use cli-output, cli-query, and cli-output-num?
- How Do I Use cli-output-rows, cli-output-cols, and cli-output-num? What Are the Precautions?
- How Do I Use cli-json-filter? What Are the Precautions?
- Other
- Videos
On this page
Show all
KooCLI allows you to set the authentication mode to AKSK and ecsAgency in a profile. AKSK is recommended. If the profile you use contains parameters related to different authentication modes, use --cli-mode to specify the mode that will be used.
hcloud CCE ListNodes --cluster_id="f288****-****-****-****-****ac101534" --project_id="0dd8cb****************19b5a84546" --cli-profile=test --cli-mode=AKSK
Parent topic: Options
