Help Center/ Koo Command Line Interface/ User Guide/ Configuration Management/ Checking the Configuration File Format
Updated on 2023-03-13 GMT+08:00
To check the format of your local configuration file, run the following command:
hcloud configure test
hcloud configure test The configuration file has the correct format.
Parent topic: Configuration Management
