Managing Graphs Using Indexes
The index management function is added to the graph access page to facilitate index addition, deletion, and search.
Creating an Index
- Access the GES graph editor. For details, see Accessing the Graph Editor.
- On the Indexes tab of the graph editor, click Create. Figure 1 Creating an index
- In the Create dialog box that appears, set the following parameters:
- Name: Enter a custom index name.
- Type:
- Memory edition: The options are Global vertex index and Global edge index.
- Database edition: The options are Global vertex index, Global edge index, Local vertex index, and Local edge index.
Note: If you select Full-Text/Vector Indexing when creating a graph, the index type can be full-text index, vertex vector index, or edge vector index.
- Label: You can choose to toggle on or off this slider. (This option is not available when the index type is vector index.)
- Label Name: This parameter is available only when Type is Local vertex index or Local edge index.
- Attribute: Only the attributes whose attribute cardinality is of the single-value type are displayed here. Multi-values are not shown. (When the index type is vector index, only one attribute is supported and the attribute type is list.) Figure 2 Parameters for creating an index
For a database edition graph, you can create any number of indexes. For a memory edition graph, you can create up to 10 indexes.
- Click OK. A dialog box appears, where you can choose whether to go to the task center to monitor the index creation progress. Figure 3 Monitoring the creation progress
- Once the creation is successful, the new index is displayed on the Indexes tab.
Deleting an Index
- On the Indexes tab of the graph editor, locate the index you want to delete and slide the scroll bar from left to right.
- Click Delete in the Operation column. Figure 4 Deleting an index
- In the Delete Index dialog box that appears, confirm the index information, manually enter DELETE or click Auto Enter, and click OK. Figure 5 Deleting an index
