Help Center/
Graph Engine Service/
User Guide/
Viewing Graph Tasks/
Task Center/
Management Plane Task Center
Updated on 2024-03-28 GMT+08:00
If you want to view details about creating, backing up, starting, backing up, importing, exporting, and upgrading tasks, you can go to the Task Center page.
The procedure is as follows:
- In the navigation pane on the left, click Task Center.
- On the Task Center page, view the task type, task name, graph name, associated graph, start time, end time, status, and running result.
Figure 1 Task center
- In the Running Result column, click View Details to view the detailed information. You can also click Cause of Failure or Job ID.
Figure 2 Viewing detailsIf the status of a data import task is Partially successful, you can click View Details to view information such as the type of data that fails to be imported and the number of rows that fail to be imported. To view the cause of failure, check the log path (optional) specified when you import the graph because failure logs are uploaded to the path.Figure 3 Partially successful task
- On the Task Center page, search for a task in any of the following ways:
Figure 4 Searching for a task
- Selecting the task type
- Selecting the task name
- Entering an associated graph
- Entering a task status
- Entering a task ID
- Setting the time
Parent topic: Task Center
