Importing Data From a Local Path or OBS
- On the GES management console, click Metadata Management in the navigation tree on the left.
- On the Metadata Management page, click Import in the upper left corner.
- In the Import dialog box, select Local or OBS for Type to import a metadata file form a local path or OBS.
- Import a metadata file from a local path.
Select Local File: Click Upload to select the metadata file.
The file must be in the XML format.
Name: Enter a name for the metadata.
Storage Path: Select an OBS path for storing the metadata file.
Figure 1 Importing metadata from a local path
- Import a metadata file from OBS.
Select File Path: Select the metadata file from OBS.
- The file must be in the XML format.
- Ensure that you have uploaded the metadata file to your OBS bucket.
Figure 2 Importing metadata from OBS
- Click OK to import the metadata.
If the import is successful, the metadata file is displayed on the Metadata Management page.
