Updated on 2025-08-14 GMT+08:00
Querying Graphs Using Cypher Statements
Cypher is a declarative graph query language. Using Cypher statements, you can query and modify data in GES and return results.
The procedure is as follows:
  1. Access the GES graph editor. For details, see Accessing the Graph Editor.
  2. Use label-based vertex and edge indexing during the compilation of Cypher queries.
    Memory edition graph: When using Cypher queries for the first time, click Create Index in the upper right corner of the result display area (this step is not required for subsequent uses).
    Database edition graph: When using Cypher queries for the first time, click Create on the Indexes tab on the left side of the canvas to create an index. For details, see Managing Graphs Using Indexes.
    Figure 1 Creating an index for a memory edition graph
    Figure 2 Creating an index for a database edition graph
  3. In the graph data query area, press Enter before entering your query statement.
Cypher Statements
The following are typical query statements.
  • Querying a vertex
    match (n:movie) return n: Query the vertex whose label is movie.
    match (n) return n limit 100: Query details about 100 vertices.
    match (n{Occupation:'artist'}) return id(n), n.Gender limit 100: Query the first 100 vertices whose Occupation is artist, and return their IDs and genders.
    match (n) where id(n)='Vivian' return n: Query the vertex whose ID is Vivian.
    match (n) return n skip 50 limit 100: Query all vertices of a graph. Skip the first 50 vertices, and return a total of 100 vertices.
  • Querying edges
    match (n)-[r]->(m) return r, n, m: Query all edges. Return the edges and vertices at both ends.
    match (n)-[r:rate]->(m) return r, n, m: Query the edges whose label is rate.
    match (n)-[r:rate|:friends]-(m) where id(n)='Vivian' return n,r,m: Query all edges whose start vertex is Vivian and edge label is rate or friends.
  • Searching by path
    match p=(n:user)--(m1:user)--(m2:movie) return p limit 100: Query the paths whose start vertex is user, first-hop end vertex is user, and second-hop end vertex is movie. Returns the first 100 paths.
  • Aggregating and deduplicating based on groups
    match (n) return count(*): Query the number of all vertices in a graph.
    match (n:user) return n.Gender, count(n): Collect statistics on the number of user vertices in every gender.
    match (n:user) return distinct n.Occupation: Return deduplicated occupations of all user vertices.
  • Sorting
    match (n:user) return id(n) as name order by name: Change IDs of all user vertices to name, and sort the vertices by name.
  • Creating a vertex
    create(n:movie{_ID_:'The Captain', Year:2019})return n: Create a vertex whose ID is The Captain, label is movie, and Year is 2019. Return the vertex.
    create(n:movie{_ID_:'The Captain', Year:2019})-[r:rate]-> (m:movie{_ID_:'The Climbers',Title: 'The Climbers', Year:2019}) return r: Create two vertices and their associated edges.
  • Creating an edge
    match (n),(m) where id(n)= 'The Captain' and id(m)= 'Lethal Weapon' create (n)-[r:rate]->(m) return r: Create an edge whose label is rate between two vertices with specified IDs. (You are advised to use this query in 2.2.21 and later versions.)
  • Modifying properties
    match (n) where id(n)= 'The Captain' set n.Title= 'The Captain' return n: Search for the vertex whose ID is The Captain and change the attribute Title to Ji Zhang.
  • Deleting a vertex
    match (n) where id(n)=' The Captain' delete n: Search and delete the vertex whose ID is The Captain.
    match (n) where id(n)=' "detach delete n": Search for the vertex whose ID is The Captain. Delete the vertex and its edges.
  • Querying a schema
    If you call db.schema() independently, only the schema metadata of the vertices is returned. Multiple isolated vertices are displayed on the canvas.
  1. You can press the up and down arrow keys in the text box to view historical query commands.
  2. When you enter a syntax keyword, the system automatically displays historical statements with the same keyword.
    Figure 3 Historical queries
  3. Keywords in the text box are displayed in different colors.
    • Reserved words in gray
      Note: A reserved word is predefined in the syntax system of a programming language. Reserved words vary depending on programming languages.
    • String values in orange
    • Key-value pairs in purple. They are of the non-string type in the key:value format.
    • Delimiters in red. Regular delimiters including square brackets [], curly brackets {}, parenthesis (), commas (,), and semicolons (;).
    • Variables in green
    Figure 4 Cypher keywords
