Using a MySQL Client to Connect to a DB Instance Over a Private Network
If your applications are deployed on an ECS that is in the same region and VPC as your DB instance, connect to the DB instance through a private IP address using an ECS.
This section describes how to connect a Linux ECS to a DB instance with SSL enabled through a private IP address. SSL encrypts connections to the DB instance, making in-transit data more secure.
Step 1: Buy an ECS
- Log in to the management console and check whether there is an ECS available.
- If there is a Linux ECS, go to 3.
- If there is a Windows ECS, see Connecting to a DB Instance Using MySQL-Front.
- If no ECS is available, go to 2.
Figure 1 ECS
- Buy an ECS and select Linux (for example, CentOS) as its OS.
To download a MySQL client to the ECS, bind an EIP to the ECS. The ECS must be in the same region, VPC, and security group as the DB instance for mutual communications.
For details about how to purchase a Linux ECS, see Purchasing an ECS in Elastic Cloud Server Getting Started.
- On the ECS Information page, view the region and VPC of the ECS.
Figure 2 ECS information
- On the Basic Information page of the DB instance, view the region and VPC of the DB instance.
Figure 3 DB instance information
- Check whether the ECS and DB instance are in the same region and VPC.
- If they are in the same region and VPC, go to Step 2: Test Connectivity and Install a MySQL Client.
- If they are in different regions, buy another instance. The ECS and DB instance in different regions cannot communicate with each other. To reduce network latency, deploy your DB instance in the region nearest to your workloads.
- If they are in different VPCs, change the VPC of the ECS to that of the DB instance. For details, see Changing a VPC.
- Log in to the ECS. For details, see Logging In to a Linux ECS Using an SSH Password in Elastic Cloud Server User Guide.
- On the Instances page of the GaussDB(for MySQL) console, click the instance name to go to the Basic Information page.
- In the Figure 4 Private IP address and database port
area, obtain the private IP address and database port.
- On the ECS, check whether the private IP address and database port of the DB instance can be connected.
- If yes, network connectivity is normal.
- If no, check the security group rules.
- If in the security group of the ECS, there is no outbound rule with Destination set to 0.0.0.0/0 and Protocol & Port set to All, add an outbound rule for the private IP address and port of the DB instance.
- If in the security group of the DB instance, there is no inbound rule with Source set to 0.0.0.0/0 and Protocol & Port set to All, add an inbound rule for the private IP address and port of the ECS. For details, see Configuring Security Group Rules.
Figure 5 DB instance security group
- Download the MySQL client installation package for Linux locally.
Find the corresponding version, for example, mysql-community-client-8.0.21-1.el6.x86_64.rpm, and download the installation package. A MySQL client running a version later than that of the DB instance is recommended.
- Upload the installation package to the ECS.
You can use any terminal connection tool, such as WinSCP and PuTTY, to upload the installation package to the ECS.
- Run the following command on the ECS to install the MySQL client:
rpm -ivh --nodeps mysql-community-client-8.0.21-1.el6.x86_64.rpm
- If any conflicts occur during the installation, add the replacefiles parameter to the command and try to install the client again.
rpm -ivh --replacefiles mysql-community-client-8.0.21-1.el6.x86_64.rpm
- If a message is displayed prompting you to install a dependency package during the installation, add the nodeps parameter to the command and install the client again.
Step 3: Connecting to the DB Instance Using Commands (SSL Connection)
- In the DB Instance Information area, check whether SSL is enabled.
- Click next to the SSL field to download Certificate Download.zip, and extract the root certificate ca.pem and bundle ca-bundle.pem from the package.
- Upload ca.pem to the ECS.
- Run the following command on the ECS to connect to the DB instance:
mysql -h <host> -P <port> -u <userName> -p --ssl-ca=<caName>
Example:
mysql -h 192.168.0.79 -P 3306 -u root -p --ssl-ca=ca.pem
Table 1 Parameter description Parameter
<host>
Private IP address of the DB instance.
<port>
Database port of the DB instance. The default value is 3306.
<userName>
Administrator account root.
<caName>
Name of the CA certificate. The certificate should be stored in the directory where the command is executed.
- Enter the password of the database account if the following information is displayed:
Enter password:
