Managing Endpoints
Viewing an Endpoint
You can view details about an endpoint, including the status, type, IP address, health check result, and weight.
- Log in to the Global Accelerator console.
- Search for the global accelerator by name or ID.
- Click the name of the global accelerator to go to the details page.
- Click Endpoint Groups.
- On the right of the page, view the endpoint information.
Modifying an Endpoint
You can modify the weight assigned to an endpoint.
- On the right of the page, locate the endpoint and click
in the Weight column. - Set a new weight for the endpoint.
If the weight is set to 0, the global accelerator will stop distributing traffic to the endpoint.
- Click OK.
Removing an Endpoint
You can remove an endpoint if you no longer need it.
After the endpoint is removed, the global accelerator will no longer forward requests to it.
- On the right of the page, locate the endpoint and click Remove in the Operation column.
You can select more than one endpoint at a time and click Remove above the list to delete them all.
