Adding an Endpoint Group
A listener needs to have at least one endpoint group where it can route traffic to.
A global accelerator has been created, and a listener has been added to it.
- Log in to the Global Accelerator console.
- Search for the global accelerator by name or ID.
- Click the name of the global accelerator to go to the details page.
- Click Listeners.
- On the right of the page, click Endpoint Groups.
- Click Add Endpoint Group.
- Specify the parameters listed in Table 1.
Table 1 Parameters required for adding an endpoint group Parameter
Name
Name of the endpoint group.
Each listener can be associated with only one endpoint group in a given region.
You can enter up to 64 characters. Only letters, digits, and hyphens are allowed.
Region
Region where the endpoint group is used.
Supplementary information about the endpoint group.
You can enter up to 255 characters.
Traffic Dial
The percentage of traffic directed to the endpoint group.
If you increase the traffic dial, more requests will be distributed to this endpoint group.
If you set the traffic dial to 0, no requests will be distributed to this endpoint group.
The weight ranges from 0 to 100.
NOTE:If a listener has multiple endpoint groups, traffic will be first distributed to the endpoint group with the lowest latency and then to other endpoint groups based on the traffic dial value you set.
Health Check
Health Check
Whether to enable health check.
If you disable health check, requests may be forwarded to unhealthy endpoints.
Protocol
The value can be TCP or UDP.
Default value: TCP
Port
The port used for health check.
The port number ranges from 1 to 65535.
Interval (s)
The maximum time between two consecutive health checks, in seconds.
The interval ranges from 1 to 60.
Timeout (s)
The maximum time required for waiting for a response to a health check request, in seconds.
The timeout ranges from 1 to 60.
Maximum Retries
The maximum number of health check retries allowed.
The value ranges from 1 to 10.
- Click OK.
