- What's New
- Function Overview
- Billing
- Getting Started
- User Guide
Best Practices
- Using Global Accelerator to Speed Up Cross-Border Access to Web Servers
- Using CDN and Global Accelerator to Speed Up Cross-Border Access
- Using Global Accelerator to Speed Up Cross-Border Access to Third-Party On-premises Servers
- Using Global Accelerator to Accelerate Communications Between Cloud and On-Premises Servers and Implement Multi-active DR
- Transferring the Source IP Address of a Client
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Global Accelerator
- Listener
- Endpoint Group
- Endpoint
- Health Check
IP Address Group
- Creating an IP Address Group
- Querying IP Address Groups
- Querying Details of an IP Address Group
- Updating an IP Address Group
- Deleting an IP Address Group
- Adding CIDR Blocks to an IP Address Group
- Removing CIDR Blocks from an IP Address Group
- Associating an IP Address Group with a Listener
- Disassociating an IP Address Group from a Listener
- Region
- Tag
- Log
- Appendix
- SDK Reference
- Can I Use the Ping Command to Test Latency?
- How Will I Be Billed for Global Accelerator?
- How Can I Increase the Global Accelerator Quotas?
- How Can I Use Traffic Dial to Distribute Traffic?
- What Types of Endpoints Can Be Added to a Global Accelerator?
- Can I Use Global Accelerator in an Area That Is Not Listed Among the Acceleration Areas?
- What Are the Statuses and Health Check Results of Endpoints?
- What Should I Do If an Endpoint Is Unhealthy?
- Most Frequently Asked Questions
- Configuring the TOA Module
- How Can I Use Global Accelerator to Enable European Users to Access the Applications Deployed in or Outside the Chinese Mainland (Excluding Europe) Faster?
Deleting a Listener
You can delete a listener if you no long need it.
If the listener has an endpoint group with endpoints, remove the endpoints and delete the endpoint group before you delete the listener.
- For details about how to remove an endpoint, see Removing an Endpoint.
- For details about how to delete an endpoint group, see Deleting an Endpoint Group.
- Log in to the Global Accelerator console.
- Search for the global accelerator by name or ID.
- Click the name of the global accelerator to go to the details page.
- Click Listeners.
- Locate the listener you want to delete and click
- In the displayed dialog box, click Yes.
Parent topic: Listeners
