- What's New
- Function Overview
- Billing
- Getting Started
- User Guide
Best Practices
- Using Global Accelerator to Speed Up Cross-Border Access to Web Servers
- Using CDN and Global Accelerator to Speed Up Cross-Border Access
- Using Global Accelerator to Speed Up Cross-Border Access to Third-Party On-premises Servers
- Using Global Accelerator to Accelerate Communications Between Cloud and On-Premises Servers and Implement Multi-active DR
- Transferring the Source IP Address of a Client
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Global Accelerator
- Listener
- Endpoint Group
- Endpoint
- Health Check
IP Address Group
- Creating an IP Address Group
- Querying IP Address Groups
- Querying Details of an IP Address Group
- Updating an IP Address Group
- Deleting an IP Address Group
- Adding CIDR Blocks to an IP Address Group
- Removing CIDR Blocks from an IP Address Group
- Associating an IP Address Group with a Listener
- Disassociating an IP Address Group from a Listener
- Region
- Tag
- Log
- Appendix
- SDK Reference
- Can I Use the Ping Command to Test Latency?
- How Will I Be Billed for Global Accelerator?
- How Can I Increase the Global Accelerator Quotas?
- How Can I Use Traffic Dial to Distribute Traffic?
- What Types of Endpoints Can Be Added to a Global Accelerator?
- Can I Use Global Accelerator in an Area That Is Not Listed Among the Acceleration Areas?
- What Are the Statuses and Health Check Results of Endpoints?
- What Should I Do If an Endpoint Is Unhealthy?
- Most Frequently Asked Questions
- Configuring the TOA Module
- How Can I Use Global Accelerator to Enable European Users to Access the Applications Deployed in or Outside the Chinese Mainland (Excluding Europe) Faster?
Deleting a Global Accelerator
If you no longer need your global accelerator and its associated listeners, endpoint groups, endpoints, and health checks, you can delete them in a few clicks.
You can delete a global accelerator if you no longer need it.
If you delete the accelerators, their associated resources, such as listeners, endpoint groups, health checks, and endpoints, will also be deleted and cannot be restored.
- Log in to the Global Accelerator console.
- Search for the global accelerator by name or ID.
- Click Delete in the Operation column.
You can select more than one accelerator at a time and click Delete above the list to delete them all.
- In the displayed dialog box, confirm the information.
Enter DELETE in the confirmation box as prompted.
Figure 1 Deleting a global accelerator - Click Yes.
- In the displayed dialog box, click Yes.
