Dependent Libraries
Supported Dependent Libraries
FunctionGraph supports both standard and third-party libraries.
  • Standard libraries
    When using standard libraries, you can import them to your inline code or package and upload them to FunctionGraph.
  • Supported non-standard libraries
    FunctionGraph provides built-in third-party components listed in Table 1 and Table 2. You can import these libraries to your inline code in the same way as you import standard libraries.
    Table 1 Third-party components integrated with the Node.js runtime
    Name
    Usage
    Version
    q
    Asynchronous method encapsulation
    1.5.1
    co
    Asynchronous process control
    4.6.0
    lodash
    Common tool and method library
    4.17.10
    esdk-obs-nodejs
    OBS sdk
    2.1.5
    express
    Simplified web-based application development framework
    4.16.4
    fgs-express
    Provides a Node.js application framework for FunctionGraph and APIG to run serverless applications and REST APIs. This component provides an example of using the Express framework to build serverless web applications or services and RESTful APIs.
    1.0.1
    request
    Simplifies HTTP invocation and supports HTTPS and redirection.
    2.88.0
    Table 2 Non-standard libraries supported by the Python runtime
    Module
    Usage
    Version
    dateutil
    Date and time processing
    2.6.0
    requests
    HTTP library
    2.7.0
    httplib2
    httpclient
    0.10.3
    numpy
    Mathematical computing
    For pip 2.7, numpy==1.16.6.
    For pip 3.10, numpy==1.24.2.
    For pip 3.9, numpy==1.18.5.
    For pip 3.6, numpy==1.18.5.
    redis
    Redis client
    2.10.5
    obsclient
    OBS client
    3.0.3
    smnsdk
    SMN access
    1.0.1
  • Other third-party libraries (FunctionGraph has no built-in non-standard third-party libraries except those listed in the preceding table.)
    Package the dependency third-party libraries and upload them to an OBS bucket or on the function details page. These libraries will then be used in your function code.
Importing Dependent Libraries
Importing a dependency for Python:
from com.obs.client.obs_client import ObsClient
Importing a dependency for Node.js:
const ObsClient = require('esdk-obs-nodejs');
For standard libraries and supported non-standard libraries, you can directly use them in your function.
For non-standard third-party libraries that are not provided by FunctionGraph, you can use them by performing the following steps:
  1. Package the dependent libraries into a ZIP file, upload the ZIP file to an OBS bucket, and obtain the OBS link URL.
  2. Log in to the FunctionGraph console, and choose Functions > Dependencies in the navigation pane.
  3. Click Create Dependency.
  4. Set the dependency name and runtime, specify the OBS link URL, and click OK.
    For details about how to obtain the OBS link URL, see Accessing an Object Using Its URL. (The following figure is for reference only. Please use the actual URL of the uploaded file package.)
    Figure 1 Obtaining the OBS link URL
    Figure 2 Setting the dependency
  5. On the function details page, click the Code tab, click Add in the Dependencies area, select the dependency created in 4, and click OK.
    Figure 3 Selecting a dependency
    Each dependency package cannot contain a file with the same name as a code file. Otherwise, the two files may be incorrectly merged or overwritten. For example, if dependency package depends.zip contains a file named index.py, the handler of a function cannot be set to index.handler. Otherwise, a code file also named index.py will be generated.
