- What's New
- Function Overview
- Billing
Getting Started
- Creating a Function from Scratch and Executing the Function
- Creating a Function Using a Template and Executing the Function
- Creating an HTTP Function Using a Container Image and Executing the Function
- Creating an Event Function Using a Container Image and Executing the Function
- Getting Started with Common Practices
User Guide
- Replacing the Temporary AK/SK
- Before You Start
- Building Functions
Configuring Functions
- Configuring Initialization
- Configuring Basic Settings
- Configuring Agency Permissions
- Configuring the Network
- Configuring Disk Mounting
- Configuring Environment Variables
- Configuring Asynchronous Execution Notification
- Configuring Single-Instance Multi-Concurrency
- Managing Versions
- Managing Aliases
- Configuring Dynamic Memory
- Configuring Heartbeat Function
- Configuring Tags
- Configuring Snapshot-based Cold Start
- Configuring a Log Group and Log Stream
- Shared VPC
- Online Debugging
Creating Triggers
- Managing Triggers
- Using a Timer Trigger
- Using an APIG (Dedicated) Trigger
- Using a Kafka Trigger
- Using a DIS Trigger
- Using an SMN Trigger
- Using an LTS Trigger
- Using a CTS Trigger
- Using a DDS Trigger
- Using a GeminiDB Mongo Trigger
- Using an APIG Trigger
- Using an APIC Trigger
- Using a DMS (for RabbitMQ) Trigger
- Using an Open-Source Kafka Trigger
- Cron Expressions for a Function Timer Trigger
- Using an EG Trigger
- Invoking the Function
- Monitoring
- Function Management
- Dependency Management
- Reserved Instance Management (Old)
- Flow Management
- Increasing Resource Quota
- GPU Function Management
- Application Center
- Sharing
- Programmable CDN Function
- CLI Command Reference
- Audit
Best Practices
- FunctionGraph Best Practices
- Processing DIS Data
- Integrating with LTS to Analyze Logs in Real Time
- Integrating with CTS to Analyze Login/Logout Security
- Periodically Starting or Stopping Huawei Cloud ECSs
- Building an HTTP Function with Spring Boot
- Creating a FunctionGraph Backend API That Uses a Custom Authorizer
- Uploading Files with FunctionGraph and APIG
- Processing IoT Data
- Workflow + Function: Automatically Processing Data in OBS
- Filtering Logs in Real Time by Using FunctionGraph and LTS
- Building an HTTP Function with Go
- Using FunctionGraph HTTP Functions to Process gRPC Requests
- Cold Start Optimization Practices
Developer Guide
- Overview
- Initializer
- Node.js
- Python
- Java
- Go
- C#
- PHP
- Development Tools
API Reference
- Before You Start
- API Overview
- Calling APIs
- Examples
- Extension and OpenTelemetry APIs
APIs
- Function Invocation
- Function Quotas
- Dependencies
- Test Events
- Function Tracing
Function Lifecycle Management
- Querying Functions
- Deleting a Function or Function Version
- Querying the Code of a Function
- Modifying the Code of a Function
- Querying the Metadata of a Function
- Modifying the Metadata of a Function
- Updating Max. Instances of a Function
- Querying Function Tags
- Enabling or Disabling the Snapshot Function
- Querying ServiceBridge Functions Bound to a Specified Function
- Querying Snapshot Status
- Querying Resource Tags
- Querying Resources
- Deleting Resource Tags
- Creating Resource Tags
- Creating a VPC Endpoint
- Deleting a VPC Endpoint
- Updating the Pinning Status of a Function
- Querying the Available ServiceBridge Version
- Versions and Aliases
- Function Metrics
- Function Logs
- Function Templates
- Reserved Instances
- Function Import and Export
- Function Triggers
Function Flows
- Executing a Flow Synchronously
- Executing a Flow Asynchronously
- Deleting Flows
- Querying a Flow
- Creating a Flow
- Querying Instances of a Flow
- Querying a Flow Instance
- Querying Metadata of a Flow Instance
- Modifying Metadata of a Flow Instance
- Querying Flow Metrics
- Querying Metrics of a Flow
- Re-executing a Flow
- Stopping a Flow
- Querying Records of a Flow in Pagination Mode
- Calling Back a Flow
- Querying Asynchronous Execution Notification Settings of a Function Version
- Deleting Asynchronous Execution Notification Settings
- Querying Asynchronous Execution Notification Settings of a Function's All Versions
- Querying Asynchronous Invocation Requests
- Querying Active Asynchronous Invocation Requests
- Stopping an Asynchronous Invocation Request
- Appendix
- Change History
- SDK Reference
General FAQs
- What Is FunctionGraph?
- Do I Need to Apply for Any Compute, Storage, or Network Services When Using FunctionGraph?
- Do I Need to Deploy My Code After Programming?
- How Do I Obtain a Token?
- What Runtimes Does FunctionGraph Support?
- How Much Disk Space Is Allocated to Each FunctionGraph Function?
- Does FunctionGraph Support Function Versioning?
- How Does a Function Read or Write Files?
- How Do I Set a Proxy When Using CLI?
- Does FunctionGraph Support Function Extension?
- Which Permissions Are Required for an IAM User to Use FunctionGraph?
- How Can I Create an ODBC Drive-based Python Dependency Package for Database Query?
- What Is the Quota of FunctionGraph?
- What Chinese Fonts Does FunctionGraph Support?
- How Does FunctionGraph Resolve a Private DNS Domain Name?
- How Does a Container Image–based Function Resolve a Private DNS Domain Name?
- How Do I Use a Domain Name to Access an API Registered with API Gateway (Dedicated)?
- What Are the Common Application Scenarios of FunctionGraph?
- Why Can't the API Gateway Domain Name Bound to a Service Be Resolved During Function Invocation?
- Does FunctionGraph Support Synchronous Transmission at the Maximum Intranet Bandwidth?
- What If the VPC Quota Is Used Up?
- How Can I Print Info, Error, or Warn Logs?
- Can I Set the Domain Name of an API to My Own Domain Name?
- Can I Change the Runtime?
- Can I Change a Function's Name?
- Why Is Message "failed to mount exist system path" Displayed?
- How Do I Obtain Uploaded Files?
- Why Can't I Receive Responses for Synchronous Invocation?
- What Should I Do If the os.system("command &") Execution Logs Are Not Collected?
- Which Directories Can Be Accessed When a Custom Runtime Is Used?
- Which Minor Versions of Python 3.6 and 3.9 Are Supported?
- Which Actions Can Be Used Instead of a VPC Administrator Agency for VPC Access?
- What Are the Possible Causes for Function Timeout?
- How Do I Obtain the Code of a Function?
- Do You Have Sample Code for Initializers?
- How Do I Enable Structured Log Query?
- Can I Enable a Listening Port in a Function to Receive External TCP Requests via EIP?
- Does FunctionGraph Support Domain Name Resolution?
- How Do I Obtain the Source IP Address of an HTTP Request Initiated by a Function?
- Function Creation FAQs
Trigger Management FAQs
- What Events Can Trigger a FunctionGraph Function?
- What If Error Code 500 Is Reported When Functions that Use APIG Triggers Return Strings?
- What Do LATEST and TRIM_HORIZON Mean in DIS Trigger Configuration?
- How Do I Use an APIG Trigger to Invoke a Function?
- How Does a Function Obtain the Request Path or Parameters When Using an APIG Trigger?
- Can I Configure a Kafka Trigger in a Different Subnet from My Function?
Dependency Management FAQs
- What Is a Dependency?
- When Do I Need a Dependency?
- What Are the Precautions for Using a Dependency?
- What Dependencies Does FunctionGraph Support?
- Does FunctionGraph Support Class Libraries?
- How Do I Use Third-Party Dependencies on FunctionGraph?
- How Do I Create Function Dependencies?
- How Do I Create a Dependency on the FunctionGraph Console?
- How Do I Add a Dependency to a Function?
Function Execution FAQs
- How Long Does It Take to Execute a FunctionGraph Function?
- Which Steps Are Included in Function Execution?
- How Does FunctionGraph Process Concurrent Requests?
- What If Function Instances Have Not Been Executed for a Long Time?
- How Can I Speed Up Initial Access to a Function?
- How Do I Know the Actual Memory Used for Function Execution?
- Why Is My First Request Slow?
- What Do I Do If an Error Occurs When Calling an API?
- How Do I Read the Request Header of a Function?
- Can the Synchronous Execution Interface Be Invoked on a Private Network?
- Why Does a Function Use More Memory Than Estimated and Even Trigger the Out of Memory Alarm?
- How Do I Check the Memory Usage When Seeing "runtime memory limit exceeded"?
- How Do I Troubleshoot "CrashLoopBackOff"?
- After I Updated an Image with the Same Name, Reserved Instances Still Use the Old Image. What Can I Do?
- Function Configuration FAQs
- External Resource Access FAQs
Other FAQs
- How Do I View the Alarm Rules Configured for a Function?
- Does FunctionGraph Support ZIP Decompiling During Video Transcoding?
- Will Resources Created During FunctionGraph 2.0 OBT Be Automatically Released When They Expire? Will Them Be Billed?
- What Is an App in FunctionGraph?
- Do I Need to Pay for Cold Start Time?
- Why Am I Seeing a Message Indicating that My Account Was Suspended When Creating a Function?
- Will the Requests of All My Functions in Different Regions Be Billed?
- Migration from FunctionGraph V1 to V2
General FAQs
More Documents
- Getting Started
- Before You Start
- Managing Versions
- Managing Aliases
- Online Debugging
- Creating Triggers
- Monitoring
- Audit
General FAQs
- Why Can't I Enable or Disable OBS Triggers by Calling APIs?
- Can I Create an OBS Trigger with an Existing Bucket?
- Other FAQs
General FAQs
- Before You Start
- API Overview
- Calling APIs
- Function Model Definition
Function Management Zone APIs
- Querying a Function List
- Publishing a Function Version
- Querying the Versions of a Function
- Creating an Alias for a Function Version
- Modifying the Alias Information About a Function Version
- Deleting an Alias of a Function Version
- Querying the Alias Information About a Function Version
- Querying the Version Alias List of a Function
- Querying All Triggers of a Function
- Querying the Information About a Trigger
- Deleting All Triggers of a Function
- Creating a Trigger
- Deleting a Trigger
- Function Data Zone APIs
- Appendix
- Change History
- Developer Guide (ME-Abu Dhabi Region)
- Getting Started
- Before You Start
- Managing Versions
- Managing Aliases
- Online Debugging
- Creating Triggers
- Monitoring
- Audit
General FAQs
- Other FAQs
General FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
- Examples
APIs
- Function Quotas
- Dependencies
- Test Events
- Function Tracing
- Function Metrics
- Function Logs
- Function Triggers
- Appendix
- Developer Guide (Kuala Lumpur Region)
- Videos
What Is a Reserved Instance?
FunctionGraph provides on-demand and reserved instances.
- On-demand instances are created and released by FunctionGraph based on actual function usage. When receiving requests to call functions, FunctionGraph automatically allocates execution resources to the requests.
- Reserved instances can be created and released by you as required. After you create reserved instances for a function, FunctionGraph preferentially forwards requests to the reserved instances. If the number of requests exceeds the processing capability of the reserved instances, FunctionGraph will forward the excessive requests to on-demand instances and automatically allocates execution resources to these requests.
After reserved instances are created for a function, the code, dependencies, and initializer of the function are automatically loaded. Reserved instances are always alive in the execution environment, eliminating the influence of cold starts on your services.
You can directly create reserved instances or create them on the function configuration page. Differences between the two modes are described in the following table.
Mode |
Advantage |
Disadvantage |
Directly creating reserved instances |
You can create a reserved instance with just a few clicks. |
Only a fixed number of reserved instances can be created. The reserved instances may be insufficient during peak hours and become idle during off-peak hours. |
Creating reserved instances on the function configuration page |
You can create different numbers of reserved instances for different periods, preventing waste of reserved instances during off-peak hours and ensuring enough reserved instances during peak hours. |
The procedure is complex. |
Directly Creating a Fixed Number of Reserved Instances
Ensure that the function, for example, Objective-func, for which you want to create reserved instances already exists on the FunctionGraph console.
- Log in to the FunctionGraph console, and choose Functions > Reserved Instances in the navigation pane.
- Click Configure Reserved Instance.
- Set the following parameters:
Table 2 Reserved instance information Parameter
App
Select the app to which the Objective-func function belongs.
Function
Select Objective-func.
Version
Select a version of the Objective-func function.
RI Quantity
Enter the number of reserved instances to be created.
To determine how many reserved instances to create, view the number of used instances in the Instance Statistics area or check the usage of the Objective-func function.
- Click OK.
After creating reserved instances for a function, you can only change the reserved instance quantity.
Creating Reserved Instances on the Function Configuration Page
The number of function instances varies between different periods. To ensure enough reserved instances during peak hours and prevent waste of reserved instances during off-peak hours, you can create a timer for invoking the corresponding function with different number of reserved instances in different periods.
- Return to the FunctionGraph console, and choose Functions > Function List in the navigation pane.
- Click Create Function.
- Set the following information.
Template
Select Create from scratch.
Function Name
Enter a name to identify the function.
App
Select default.
Agency
Select Use no agency.
Enter a description for the function. This parameter is optional.
Runtime
Select Python 2.7.
Handler
Enter index.handler.
Code Entry Mode
When creating a function, select Default code. On the Configuration tab page, select Edit code inline and enter the following code:
# -*- coding:utf-8 -*- import json import requests def handler (event, context): domainId = "https://{Endpoint}" url = "/v2/{project_id}/fgs/functions/{func-urn}/reservedinstances" token = context.getToken() requrl = domainId + url headerdata = {"Content-Type":"application/json","x-auth-token":token} r = requests.put(requrl, data=event["user_event"], headers=headerdata,verify=False) return r.json
Replace the following parameters with the actual values:
- Endpoint: Endpoint of the Objective-func function. For details, see Regions and Endpoints.
- project_id: ID of the project to which the Objective-func function belongs. For details, see Obtaining a Project ID.
- func-urn: URN of the Objective-func function.
- On the Configuration tab page, click Create Agency.
- Create an agency and grant it the FunctionGraph User permission. For details, see Configuring Agency Permissions.
- On the Configuration tab page, select the agency created in 6, and click Save.
- On the Triggers tab page, click Create Trigger.
Trigger Type
Select Timer.
Timer Name
Enter a name to identify the timer.
Rule
Select Cron expression and enter a cron expression as required.
Enable Trigger
By default, this function is enabled. Retain the default setting.
Additional Information
Enter the number of reserved instances required in different periods based on the trigger rule.
Figure 1 shows a timer trigger that requests FunctionGraph to create two reserved instances every 3 minutes.
- Click OK.
After trigger creation, different numbers of reserved instances will be created for the Objective-func function in different periods based on the trigger rule.
