- What's New
- Function Overview
- Billing
Getting Started
- Creating a Function from Scratch and Executing the Function
- Creating a Function Using a Template and Executing the Function
- Creating an HTTP Function Using a Container Image and Executing the Function
- Creating an Event Function Using a Container Image and Executing the Function
- Getting Started with Common Practices
User Guide
- Replacing the Temporary AK/SK
- Before You Start
- Building Functions
Configuring Functions
- Configuring Initialization
- Configuring Basic Settings
- Configuring Agency Permissions
- Configuring the Network
- Configuring Disk Mounting
- Configuring Environment Variables
- Configuring Asynchronous Execution Notification
- Configuring Single-Instance Multi-Concurrency
- Managing Versions
- Managing Aliases
- Configuring Dynamic Memory
- Configuring Heartbeat Function
- Configuring Tags
- Configuring Snapshot-based Cold Start
- Configuring a Log Group and Log Stream
- Stateful Functions
- Shared VPC
- Online Debugging
Creating Triggers
- Managing Triggers
- Using a Timer Trigger
- Using an APIG (Dedicated) Trigger
- Using a Kafka Trigger
- Using a DIS Trigger
- Using an SMN Trigger
- Using an LTS Trigger
- Using a CTS Trigger
- Using a DDS Trigger
- Using a GeminiDB Mongo Trigger
- Using an APIG Trigger
- Using an APIC Trigger
- Using a DMS (for RabbitMQ) Trigger
- Using an Open-Source Kafka Trigger
- Cron Expressions for a Function Timer Trigger
- Using an EG Trigger
- Invoking the Function
- Monitoring
- Function Management
- Dependency Management
- Reserved Instance Management (Old)
- Flow Management
- Increasing Resource Quota
- GPU Function Management
- Application Center
- Sharing
- Programmable CDN Function
- CLI Command Reference
- Audit
Best Practices
- FunctionGraph Best Practices
- Processing DIS Data
- Integrating with LTS to Analyze Logs in Real Time
- Integrating with CTS to Analyze Login/Logout Security
- Periodically Starting or Stopping Huawei Cloud ECSs
- Building an HTTP Function with Spring Boot
- Creating a FunctionGraph Backend API That Uses a Custom Authorizer
- Uploading Files with FunctionGraph and APIG
- Processing IoT Data
- Workflow + Function: Automatically Processing Data in OBS
- Filtering Logs in Real Time by Using FunctionGraph and LTS
- Deploying AI Drawing Stable-Diffusion in the Application Center
- Building an HTTP Function with Go
- Using FunctionGraph HTTP Functions to Process gRPC Requests
- Cold Start Optimization Practices
Developer Guide
- Overview
- Initializer
- Node.js
- Python
- Java
- Go
- C#
- PHP
- Development Tools
API Reference
- Before You Start
- API Overview
- Calling APIs
- Examples
- Extension and OpenTelemetry APIs
APIs
- Function Invocation
- Function Quotas
- Dependencies
- Test Events
- Function Tracing
Function Lifecycle Management
- Querying Functions
- Deleting a Function or Function Version
- Querying the Code of a Function
- Modifying the Code of a Function
- Querying the Metadata of a Function
- Modifying the Metadata of a Function
- Updating Max. Instances of a Function
- Querying Function Tags
- Enabling or Disabling the Snapshot Function
- Querying ServiceBridge Functions Bound to a Specified Function
- Querying Snapshot Status
- Querying Resource Tags
- Querying Resources
- Deleting Resource Tags
- Creating Resource Tags
- Creating a VPC Endpoint
- Deleting a VPC Endpoint
- Updating the Pinning Status of a Function
- Querying the Available ServiceBridge Version
- Versions and Aliases
- Function Metrics
- Function Logs
- Function Templates
- Reserved Instances
- Function Import and Export
- Function Triggers
Function Flows
- Executing a Flow Synchronously
- Executing a Flow Asynchronously
- Deleting Flows
- Querying a Flow
- Creating a Flow
- Querying Instances of a Flow
- Querying a Flow Instance
- Querying Metadata of a Flow Instance
- Modifying Metadata of a Flow Instance
- Querying Flow Metrics
- Querying Metrics of a Flow
- Re-executing a Flow
- Stopping a Flow
- Querying Records of a Flow in Pagination Mode
- Calling Back a Flow
- Querying Asynchronous Execution Notification Settings of a Function Version
- Deleting Asynchronous Execution Notification Settings
- Querying Asynchronous Execution Notification Settings of a Function's All Versions
- Querying Asynchronous Invocation Requests
- Querying Active Asynchronous Invocation Requests
- Stopping an Asynchronous Invocation Request
- Appendix
- Change History
- SDK Reference
General FAQs
- What Is FunctionGraph?
- Do I Need to Apply for Any Compute, Storage, or Network Services When Using FunctionGraph?
- Do I Need to Deploy My Code After Programming?
- How Do I Obtain a Token?
- What Runtimes Does FunctionGraph Support?
- How Much Disk Space Is Allocated to Each FunctionGraph Function?
- Does FunctionGraph Support Function Versioning?
- How Does a Function Read or Write Files?
- How Do I Set a Proxy When Using CLI?
- Does FunctionGraph Support Function Extension?
- Which Permissions Are Required for an IAM User to Use FunctionGraph?
- How Can I Create an ODBC Drive-based Python Dependency Package for Database Query?
- What Is the Quota of FunctionGraph?
- What Chinese Fonts Does FunctionGraph Support?
- How Does FunctionGraph Resolve a Private DNS Domain Name?
- How Does a Container Image–based Function Resolve a Private DNS Domain Name?
- How Do I Use a Domain Name to Access an API Registered with API Gateway (Dedicated)?
- What Are the Common Application Scenarios of FunctionGraph?
- Why Can't the API Gateway Domain Name Bound to a Service Be Resolved During Function Invocation?
- Does FunctionGraph Support Synchronous Transmission at the Maximum Intranet Bandwidth?
- What If the VPC Quota Is Used Up?
- How Can I Print Info, Error, or Warn Logs?
- Can I Set the Domain Name of an API to My Own Domain Name?
- Can I Change the Runtime?
- Can I Change a Function's Name?
- Why Is Message "failed to mount exist system path" Displayed?
- How Do I Obtain Uploaded Files?
- Why Can't I Receive Responses for Synchronous Invocation?
- What Should I Do If the os.system("command &") Execution Logs Are Not Collected?
- Which Directories Can Be Accessed When a Custom Runtime Is Used?
- Which Minor Versions of Python 3.6 and 3.9 Are Supported?
- Which Actions Can Be Used Instead of a VPC Administrator Agency for VPC Access?
- What Are the Possible Causes for Function Timeout?
- How Do I Obtain the Code of a Function?
- Do You Have Sample Code for Initializers?
- How Do I Enable Structured Log Query?
- Can I Enable a Listening Port in a Function to Receive External TCP Requests via EIP?
- Does FunctionGraph Support Domain Name Resolution?
- How Do I Obtain the Source IP Address of an HTTP Request Initiated by a Function?
- Function Creation FAQs
Trigger Management FAQs
- What Events Can Trigger a FunctionGraph Function?
- What If Error Code 500 Is Reported When Functions that Use APIG Triggers Return Strings?
- What Do LATEST and TRIM_HORIZON Mean in DIS Trigger Configuration?
- How Do I Use an APIG Trigger to Invoke a Function?
- How Does a Function Obtain the Request Path or Parameters When Using an APIG Trigger?
- Can I Configure a Kafka Trigger in a Different Subnet from My Function?
Dependency Management FAQs
- What Is a Dependency?
- When Do I Need a Dependency?
- What Are the Precautions for Using a Dependency?
- What Dependencies Does FunctionGraph Support?
- Does FunctionGraph Support Class Libraries?
- How Do I Use Third-Party Dependencies on FunctionGraph?
- How Do I Create Function Dependencies?
- How Do I Create a Dependency on the FunctionGraph Console?
- How Do I Add a Dependency to a Function?
Function Execution FAQs
- How Long Does It Take to Execute a FunctionGraph Function?
- Which Steps Are Included in Function Execution?
- How Does FunctionGraph Process Concurrent Requests?
- What If Function Instances Have Not Been Executed for a Long Time?
- How Can I Speed Up Initial Access to a Function?
- How Do I Know the Actual Memory Used for Function Execution?
- Why Is My First Request Slow?
- What Do I Do If an Error Occurs When Calling an API?
- How Do I Read the Request Header of a Function?
- Can the Synchronous Execution Interface Be Invoked on a Private Network?
- Why Does a Function Use More Memory Than Estimated and Even Trigger the Out of Memory Alarm?
- How Do I Check the Memory Usage When Seeing "runtime memory limit exceeded"?
- How Do I Troubleshoot "CrashLoopBackOff"?
- After I Updated an Image with the Same Name, Reserved Instances Still Use the Old Image. What Can I Do?
- Function Configuration FAQs
- External Resource Access FAQs
Other FAQs
- How Do I View the Alarm Rules Configured for a Function?
- Does FunctionGraph Support ZIP Decompiling During Video Transcoding?
- Will Resources Created During FunctionGraph 2.0 OBT Be Automatically Released When They Expire? Will Them Be Billed?
- What Is an App in FunctionGraph?
- Do I Need to Pay for Cold Start Time?
- Why Am I Seeing a Message Indicating that My Account Was Suspended When Creating a Function?
- Will the Requests of All My Functions in Different Regions Be Billed?
- Migration from FunctionGraph V1 to V2
General FAQs
More Documents
- Getting Started
- Before You Start
- Managing Versions
- Managing Aliases
- Online Debugging
- Creating Triggers
- Monitoring
- Audit
General FAQs
- Why Can't I Enable or Disable OBS Triggers by Calling APIs?
- Can I Create an OBS Trigger with an Existing Bucket?
- Other FAQs
General FAQs
- Before You Start
- API Overview
- Calling APIs
- Function Model Definition
Function Management Zone APIs
- Querying a Function List
- Publishing a Function Version
- Querying the Versions of a Function
- Creating an Alias for a Function Version
- Modifying the Alias Information About a Function Version
- Deleting an Alias of a Function Version
- Querying the Alias Information About a Function Version
- Querying the Version Alias List of a Function
- Querying All Triggers of a Function
- Querying the Information About a Trigger
- Deleting All Triggers of a Function
- Creating a Trigger
- Deleting a Trigger
- Function Data Zone APIs
- Appendix
- Change History
- Developer Guide (ME-Abu Dhabi Region)
- Getting Started
- Before You Start
- Managing Versions
- Managing Aliases
- Online Debugging
- Creating Triggers
- Monitoring
- Audit
General FAQs
- Other FAQs
General FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
- Examples
APIs
- Function Quotas
- Dependencies
- Test Events
- Function Tracing
- Function Metrics
- Function Logs
- Function Triggers
- Appendix
- Developer Guide (Kuala Lumpur Region)
- Videos
Processing Stream Files
This section describes how to use FunctionGraph to process large stream files. Create an express flow that meets your service requirements.
Background and Value
Serverless workflows feature orchestration, state management, persistence, visualized monitoring, error handling, and cloud service integration. They are suitable for many scenarios, including:
- Complex, abstract services, such as order management and CRM
- Services that require automatic interruption and recovery when manual intervention is involved among tasks, such as manual review and pipeline deployment
- Services that require manual interruption and recovery, such as data backup and restoration
- Task status monitoring
- Stream processing, such as log analysis and image/video processing
Nowadays, most serverless workflow platforms focus more on control process orchestration rather than data flow orchestration and transmission. In scenarios similar to Creating a Flow Trigger, the data flow is simple and well supported by various platforms. However, they do not have a solution for ultra-large data stream processing scenarios, such as file transcoding. For these scenarios, Huawei Cloud FunctionGraph provides the serverless streaming solution, which responds to process files within milliseconds.
Principles
Huawei Cloud FunctionGraph provides the serverless streaming solution for file processing via orchestration. Steps are driven by data flows, which is easier to understand. This section uses image processing as an example to describe how this solution works.
A workflow system needs to process two parts:
- Control flow: Controls the flow between steps and the execution of serverless functions in the steps.
- Data flow: Controls the data flowing through the entire workflow. Generally, the output of a previous step serves as the input of the next step. For example, in the preceding image processing workflow, the image compression result is the input of the watermarking step.
In common service orchestration, the execution sequence of each service needs to be precisely controlled, so the control flow is the core of a workflow. However, streaming processing scenarios such as file processing do not require more on the control flow. For example, in the image processing scenario, large images can be processed by block. Image compression and watermarking are not necessarily completed in a specific sequence.
The following figure shows the architecture of Huawei Cloud FunctionGraph's serverless streaming solution.
Serverless streaming allows steps to be executed in parallel rather than in a specific sequence. Steps interact with each through data flows, which are controlled by the Stream Bridge component. The function SDKs include a streaming data API, which writes data into Stream Bridge in a gRPC stream. Stream Bridge then distributes the data flow into the function pod in the next step.
- Create an image compression function, which uses ctx.Write() to return results as streaming data.
Currently, only Go functions are supported.
FunctionGraph supports streaming response with ctx.Write(). Instead of focusing on network transmission, you only need to return the final results in a stream.
- Create a workflow on the FunctionGraph console.
- Invoke the synchronous flow execution API to obtain the file stream. The data is returned to the client in chunked streaming mode.
