Updated on 2025-12-04 GMT+08:00
Modifying the Specifications of a FlexusX Instance
If the FlexusX instance you purchased cannot meet service requirements, you can upgrade the vCPUs and memory by modifying the instance specifications or change the instance to an ECS.
Notes
  • Downgrading FlexusX instance specifications (vCPUs or memory) will reduce performance.
  • The specifications of a FlexusX instance cannot be modified when the instance is in an intermediate state, such as starting, stopping, resetting the OS, or migrating, or when the capacity of EVS disks used by the instance is being expanded.
  • Before modifying the specifications of a Windows instance, modify the SAN policy by following the instructions provided in What Should I Do If a Disk Is Offline? in the ECS documentation to prevent offline disks after the specifications are modified.
  • A specification change failure may result in data loss for the FlexusX instance. Back up the data before the change. For details, see Backing Up a FlexusX Instance.
The selected instances must use the same billing mode, use the same flavor, and be in the same AZ.
Billing
Modifying specifications will change how much you are billed for the instances. For details, see Pricing of a Changed Specification.
Preparations
If the NIC retaining is enabled in the OS, NIC flapping may happen after the instance specifications are modified. To prevent such issues, perform the following operations before modifying the specifications:
  • Linux
    Run the following commands on the ECS to delete the files with both persistent and net included in their names from the network rule directory:
    rm -fr /etc/udev/rules.d/*net*persistent*.rules
    rm -fr /etc/udev/rules.d/*persistent*net*.rules
  • Windows
    Delete the following directories from the registry on the ECS:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkList\Profiles
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkList\Signatures\Unmanaged
    Figure 1 Registry
For more information about network interface flapping, see What Should I Do If NIC Flapping Occurs After My ECS Specifications Are Modified?
You can change the specifications of a FlexusX instance to other FlexusX specifications, or you can change a FlexusX instance to an ECS for even more options.
  1. Log in to the FlexusX console. In the upper left corner, click and select a region.
  2. Locate the FlexusX instance and choose More > Modify Specifications in the Operation column.
  3. On the displayed page, select desired instance specifications.
    FlexusX has a performance mode option to provide fantastic, stable performance at additional charges. For more information, see Enabling Performance Mode for a FlexusX Instance.
    • Select new specifications.
      Figure 2 New specifications
    • Confirm the change.
      Figure 3 Confirming the change
      • If you select Stop and change, the specifications are modified after automatic system shutdown.
      • If Apply for Live Change is selected, the specifications can be modified without system shutdown. The live change function is in the open beta testing (OBT) phase. Apply for the function as needed. If this option is not displayed on the console, live change is not supported. For details about live change, see What Is Live Change?
  4. Read and agree to the agreement, and click Submit.
    After the modification is complete, check whether the new specifications are displayed on the FlexusX instance list page.
    Figure 4 Viewing new specifications
  2. Select the FlexusX instances whose specifications you want to modify, choose More > Modify Specifications above the list, and click For Pay-per-Use FlexusX Instances or For Yearly/Monthly FlexusX Instances.
    • Before modifying the specifications, stop the cloud server or select Automatically stop the ECS during specifications modification.
      FlexusX X1 instances have performance mode disabled, and FlexusX X1e instances have performance mode enabled.
    Figure 5 Batch modifying specifications
  4. Read and agree to the disclaimer, and click Submit.
    After the change, if you selected FlexusX specifications, check whether the new specifications are displayed on the FlexusX instance list page. If you selected ECS specifications, check whether the new specifications are displayed on the ECS list page.
    Figure 6 Viewing new specifications
    Figure 7 Viewing new specifications on the ECS list page
  2. Locate the row that contains the target FlexusX instance and choose More > Change to ECS in the Operation column.
    • Before modifying the specifications, manually stop the FlexusX instance or select Authorize ECS auto-stop.
    • Select the new ECS type and specifications.
  4. Click Next.
  5. Confirm the settings, read and select the disclaimer, and then click Submit.
    Wait until the modification is complete and check whether the new specifications are displayed on the ECS list page.
    Figure 8 Viewing new specifications on the ECS list page
Follow-Up Operations
After the specifications of an instance are modified, disks may fail to be mounted. Check disk statuses after the specifications are modified.
