- Getting Started
User Guide
- Using IAM to Grant Access to FlexusX
- Purchasing a FlexusX Instance
- Logging In to a FlexusX Instance
- Managing FlexusX Instances
- Managing Images
- Managing EVS Disks
VPC Management
- VPC Overview
- Attaching Extension Network Interfaces to a FlexusX Instance
- Detaching Extension Network Interfaces from a FlexusX Instance
- Changing the VPC for a FlexusX Instance
- Changing the Private IP Address of the Primary Network Interface for a FlexusX Instance
- Configuring a Virtual IP Address for a FlexusX Instance
- Managing EIPs
- Managing Server Security
- Managing Backups
- Viewing Monitoring Metrics and Configuring Alarms
- API Reference
- Product Consulting
- Billing
- OS and Image
- Specification Modification FAQ
Performance Mode
- How Do I Know Whether Performance Mode Is Enabled for a FlexusX Instance?
- How Much Can Performance Be Improved If Performance Mode Is Enabled for a Flexus X Instance?
- Do I Need to Stop My FlexusX Instance If I Want to Enable or Disable Performance Mode for It?
- Can I Enable Performance Mode After a FlexusX Instance Is Created?
- Will I Continue to Be Billed If I Disable Performance Mode for My FlexusX Instance?
- Password
Attaching Existing EVS Disks to a FlexusX Instance
If the disks of a FlexusX instance cannot meet service requirements, for example, there is not enough disk space, you can attach more available disks to the FlexusX instance.
- EVS disks can only be attached to FlexusX instances in the same region.
- Non-shared disks can be only attached when they are in the Available state.
Shared disks can be attached when they are in the In-use or Available state.
- A FlexusX instance must be in the Running or Stopped state to allow EVS disks to be attached to it.
- A frozen EVS disk cannot be attached to a FlexusX instance.
- A SCSI EVS disk cannot be attached as the system disk to a FlexusX instance.
- A detached system disk can be used as a data disk for any FlexusX instances, but can only be used as a system disk for the FlexusX instance where it was attached before.
- A detached data disk that is purchased together with a FlexusX instance can only be used as a data disk for this instance.
For details about attaching disks, see Attaching a Non-Shared Disk and Attaching a Shared Disk.
- EVS disks are available.
For instructions about how to purchase an EVS disk, see Purchasing an EVS Disk.
- Log in to the FlexusX console, in the upper left corner, click
, and select a region.
- Click the name of the FlexusX instance you want to attach a disk to.
- Click the Disks tab. Then, click Attach Disk.
- Select the target disk and set the disk function as prompted.
Figure 1 Attaching an EVS disk
- Click OK.
After the disk is attached, you can view the disk information on the Disks tab.
Follow-Up Operations
If the attached disk is newly created, you must log in to the FlexusX instance and initialize the EVS disk before you can use them. For details about how to initialize a data disk, see Initializing a Data Disk.
