Unbinding an EIP from a FlexusX Instance
If your FlexusX instance no longer needs an EIP or you want to bind the EIP to another instance, unbind the EIP from the FlexusX instance first.
This section describes how to unbind an EIP from a FlexusX instance.
Billing
If you do not release a pay-per-use EIP after unbinding it, it will generate additional costs. If you no longer need it, release it by referring to Releasing or Unsubscribing From an EIP.
- Log in to the FlexusX console. In the upper left corner, click
and select a region. - Locate the target FlexusX instance, and in the Operation column, choose More > Manage Network > Unbind EIP.
- Confirm the EIP information and click OK.
Unreleased EIPs will continue to be billed. Release them if you do not need them anymore.
